For Sale Diamond Pistons, Turbo Lsj Oil Pan, Valve Cover and More
Old Nov 1, 2011 | 07:23 PM
Frew's Avatar
So I started another for sale thread, the old one was cluttered up and alot of stuff sold so i thought I would clean it up. Will ship something that fits in a flat rate box to Canada.
lsj coils. 75 shipped for 4
Fe1 sway links, brand new. 30 shipped
Diamond pistons, stock bore, stock compression, new wrist pins, new spirlocks, 20k miles. Sold!!!
Brand new total seals. Sold!!!
Stock cobalt bezel. 20+shipping
Turbo lsj oil pan, -10 an fitting welded on, comes with fitting too. 100 shipped
Phenolic spacer SOLD
Stock lsj short block minus rotating assembly, sleeve #4 has a slight wave in it, roughly 1" long mid sleeve, not sure if it can be honed out, worst case resleeve that cylinder. Includes girdle and crank position sensor, everything under the front cover (balance shafts, chains, guides, etc). Also includes the front cover and oil pump. Asking 200+shipping
GM 42's with harness, 40k miles. 80 shipped
GM stage 2 pulley, 2.9, 2.8. 30 shipped (2.8 SOLD)
GM hub. SOLD!!!
lsj valve cover with gaskets. SOLD!!!
Stock lsj oil pan. 80 shipped
Coil cover. 20+shipping
Stock lsj downpipe to 3" catback reducer. 20+shipping
Brand new ceramic Lsj Power Stop front and rear pads. SOLD!!!
Steering rack spacers, control bump steer on a cobalt. 20 shipped
AEM intake, AEM dryflow filter, MAF bolts were seized in they will need drilled and retapped, I don't feel like doing it. 60 shipped
Old Nov 1, 2011 | 09:07 PM
SCobaltblu's Avatar
Were the pistons the ones used in the bad block for sale?
Old Nov 1, 2011 | 09:34 PM
Frew's Avatar
no sir, pistons were pulled out of a good running motor, stock pistons were in that motor and 3 out of 4 pistons had cracked or exploded ringlands
Old Nov 2, 2011 | 06:17 PM
Frew's Avatar
Bump, who needs pistons to do a winter build?
Old Nov 2, 2011 | 10:29 PM
Frew's Avatar
bump, intake, pads, and spacers added
Old Nov 3, 2011 | 06:18 PM
kxrida2000's Avatar
ill give u $1 for it all
free bump
Old Nov 3, 2011 | 06:21 PM
Frew's Avatar
Sell those wheels you just bought and you could buy the whole lot plus have monies left over
Old Nov 4, 2011 | 12:47 AM
Tennpenn83's Avatar
free bump for a good guy!
Old Nov 4, 2011 | 12:51 AM
carstedt's Avatar
damn all i need is pistons and rods to finish my build...to bad i dont got the money yet
Old Nov 5, 2011 | 04:05 PM
Frew's Avatar
Thanks man, best of luck with your build
heres your pistons
Old Nov 5, 2011 | 05:21 PM
kxrida2000's Avatar
bump for good seller!
Old Nov 6, 2011 | 02:40 PM
Frew's Avatar
Thanks guy!
Old Nov 9, 2011 | 07:40 AM
Frew's Avatar
To the top
Old Nov 9, 2011 | 09:55 PM
Frew's Avatar
bump, come on guys, make me some offers
Old Nov 10, 2011 | 09:28 PM
SCobaltblu's Avatar
I'm still interested in those pistons but my issue is, do they fit into another block like brand new? I'm assuming through hundreds of heat cycles in your engine, they have expanded and contracted to make themselves a perfect fit in the cylinders. Just wondering if its possible for them to not fit in my cylinders. That's how my stupid mind works! I've been burned several times on used parts, and this isn't something you can just reverse in an hour!
Old Nov 10, 2011 | 09:33 PM
Frew's Avatar
pm sent ur way
Old Nov 10, 2011 | 09:35 PM
FryLoch's Avatar
I'll take that spacer, is it still in good shape? No warps cracks etc etc?
Old Nov 10, 2011 | 09:38 PM
Frew's Avatar
pmage
Old Nov 11, 2011 | 08:50 AM
kxrida2000's Avatar
U realize the piston doesn't contact the cylinder wall right? The rings do so they will be just fine
Old Nov 11, 2011 | 01:15 PM
SCobaltblu's Avatar
Ya, I know how an engine works, but they still expand and contract so the tolerances can change. I didnt word my original post right. 1.5hrs of sleep in 36hrs > my mind. I need to think if I want to continue to mod the car.
Old Nov 12, 2011 | 11:02 AM
Frew's Avatar
Im telling you there is no chance of forged pistons expanding or contacting enough to not fit in the cylinder bore. It just doesn't happen.
Old Nov 12, 2011 | 10:25 PM
jittjoey's Avatar
any chance u can make a deal on the oil pan to 43968
Old Nov 12, 2011 | 10:33 PM
Frew's Avatar
Pmed
Old Nov 15, 2011 | 07:41 AM
Frew's Avatar
Cobalts in escrow bump
Old Nov 17, 2011 | 07:46 AM
Frew's Avatar
Bump taking reasonable offers
