For Sale Dual Aeroforce Interceptor Gauges
Old Oct 13, 2009 | 05:22 PM
solution's Avatar
Basically brand new. I only used them for three months. Getting rid of them because I went back to stock. Looking for $350 Shipped OBO Thanks! (PT Series) F.Y.I.
Old Oct 13, 2009 | 05:25 PM
cradleoffear06's Avatar
Will you seperate? I just need one
Old Oct 13, 2009 | 05:34 PM
solution's Avatar
No can do. It comes with a 2 in 1 ODB2 connection. So it will be pointless to just sell only one. Unless I get someone else that wants only one as well, then I will split it up.
Old Oct 13, 2009 | 05:53 PM
~Mike~'s Avatar
If they were sold as duals, they won't opperate on their own. The have to stay together from what I've heard
Old Oct 13, 2009 | 05:54 PM
solution's Avatar
Thank for the info! So they are selling together =)
Old Oct 14, 2009 | 01:44 PM
solution's Avatar
Bump.
Old Oct 15, 2009 | 02:16 PM
solution's Avatar
Bump....Shoot me some offers.
Old Oct 15, 2009 | 02:19 PM
cobalt_ss187's Avatar
so just to make sure this works for the 2.2, 2.4, 2.0 lnf?
Old Oct 15, 2009 | 02:49 PM
buellfooll's Avatar
2 questions. What parameters did you actually monitor and were you able to monitor A/F ratio (wideband) with the veh's stock O2?
Old Oct 15, 2009 | 09:50 PM
solution's Avatar
It will work (any GM vehicle).
I have the list a parameters that it uses.
A1A-GM Supported Parameters (PID’S)
1. INTAKE AIR- Intake Air Temperature - **
2. COOLANT TEMP- Engine Coolant Temperature **
3. TRANS TEMP 1- Transmission Temperature for automatic gas vehicles
4. TRANS TEMP 2- Trans temp for some vehicles made from ’94-’97.
4. RPM- engine Revolutions Per Minute **
5. MAF SENSOR LB/M- Mass Air Flow (lbs/min) **
6. MAF FREQUENCY- raw Mass Air Flow sensor output (frequency)
7. MAF FREQUENCY 2- raw MAF sensor output for the Cobalt SS and Redline
8. MAP SENSOR- Manifold Air Pressure (kPa) **
9. BOOST – Intake vacuum/boost displayed in inHg/PSI. Corrected by altitude entry or barometer**
9. THROTTLE POS. PCT- Throttle Position percentage (0-100%)
10. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
11. MILES PER HOUR- Miles Per Hour **
12. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
13. KNOCK RETARD 2- used for KR value of ’94-’97 LT1’s and some 96/97 V8’s.
14. KNOCK RETARD 3- used for knock retard value of the Cobalt SS SC and Redline
15. IGNITION ADVANCE- ignition timing advance
16. PULSE WIDTH- injector #1 pulse width (4&6 cylinder engines)
17. SHORT TRIM B1-short term fuel trim bank#1
18. SHORT TRIM B2-short term fuel trim bank#2
19. LONG TRIM B1-long term fuel trim bank#1
20. LONG TRIM B2-long term fuel trim bank#2
21. OXYGEN SENSOR B1-O2 bank 1 sensor 1 in millivolts
22. OXYGEN SENSOR B2-O2 bank 2 sensor 1 in millivolts
23. OXYGEN SENSOR – alternate O2 sensor parameter, rarely supported.
24. RUN TIME MINS- engine run time is tenths of seconds since last engine start **
25. BATTERY VOLTAGE- Alternator/battery output voltage **
26. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve)
27. PULSE WIDTH B1-injector Pulse Width for bank 1 (8 cylinder engines)
28. PULSE WIDTH B2-injector Pulse Width for bank 2 (8 cylinder engines)
29. ENGINE LOAD- calculated Engine Load (0-100%) **
30. ENGINE OIL PRESSURE (some 8 cylinder engines) **
31. INTAKE AIR 2 – Intake Air Temp. downstream of intercooler (some supercharged applications such as the
Cobalt SS, Ion Redline).
32. TRANS TEMP AL- Allison transmission temp, Duramax and Workhorse
33. TORQUE CONVERTER SLIP AL- Allison transmission converter slip, Duramax and Workhorse
34. TQ TO TRANS AL- Engine torque delivered to trans, Duramax and Workhorse
35. INJECTOR RAIL PRESSURE DESIRED DM- Duramax
36. INJECTOR RAIL PRESSURE ACTUAL DM- Duramax
37. THROTTLE PCT DM- Throttle percentage- Duramax
38. THROTTLE VOLTS DM- Throttle sensor voltage- Duramax
39. FUEL LEVEL DM- Duramax
40. INJECTOR FLOW RATE DM- Duramax
41. Desired Turbo Vane Position- 2004+ Duramax
42. Actual Turbo Vane Position- 2004+ Duramax
43. Pilot Injector Pulse Width- pilot injector pulse width in msec. - Duramax
44. Main Injector Pulse Width- main injector pulse width in msec. - Duramax
45. Pilot Injector Timing- in degrees - Duramax
46. Main Injector Timing- in degrees - Duramax
47. Pilot Injector Fuel Rate- mm^3 - Duramax
48. Main Injector Fuel Rate- mm^3 - Duramax
49. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
50. Miles Per Gallon 2- instantaneous fuel economy for diesel vehicles
51. HP 1- Calculated net horsepower for gasoline vehicles
52. HP 2- Calculated net horsepower for diesel vehicles
53. Analog 1 – analog input #1.
54. Analog 2 – analog input #2
55. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute.
56. BAROMETRIC PRESSURE- limited support on standard GM vehicles, DM support
57. PITCH – H2 Hummer support – indicates the angle of inclination of the vehicle.
58. CURRENT GEAR- Current gear of the transmission
59. TORQUE- Calculated torque from engine to transmission
60. SHIFT TIME- time (msec) for last shift to occure.
61. TORQUE CONVERTER SLIP – Amount of slip allowed by torque converter
62. TORQUE CONVERTER STATUS- Indicates whether torque converter is locked (L) or unlocked (UL)
**These standard GM parameters also are supported by the Duramax diesel
Old Oct 15, 2009 | 11:11 PM
redbalt's Avatar
pm'd
Old Oct 15, 2009 | 11:38 PM
solution's Avatar
Replied.
Old Oct 16, 2009 | 12:07 PM
buellfooll's Avatar
I understand the parameters the gauge is capable of reading but the DATA for all of them is not available at the OBD port of all cars. Is A/F data available at the port on the SS/TC? Can you read A/F ratio on YOUR car?
Old Oct 16, 2009 | 02:07 PM
solution's Avatar
I too understand they are not capable of reading all data on all cars, but those parameters listed is readable on GM vehicles. Hint: That is why I listed them. They have different parameters for FORD vehicles as well and etc.... No, these gauges do not read A/F.
Old Oct 17, 2009 | 03:49 PM
solution's Avatar
Bump.
Old Oct 17, 2009 | 04:03 PM
mkulrey13's Avatar
They will not work on ANY. Either its for the 2.0 LSJ or 2.2/2.4/2.0 LNF. Assumming you didnt do some motor swap in your cav, its for the 2.2/2.4/2.0 LNF Cars
Old Oct 17, 2009 | 04:08 PM
MikeyB's Avatar
You can read AFR with these gauges, you have to have a wideband O2 sensor and wire it to one of the outputs on the intercepter
Also as far as i know the aeroforce thatworks on the 2.2 does not work on the LSJ but i have no idea about 2.4 and LNF
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
