Ecotec L61 core engine
Old Jul 4, 2006 | 12:02 AM
Halfcent's Avatar
I'm old school
This engine is completely disassembled for inspection. Head is included, just not pictured. All parts are bagged and tagged. Engine was pulled from a 2003 Cavalier under warranty due to a timing chain failure. Failure resulted in bent valves and a damaged piston. It is completely rebuildable. Some parts were disposed of during disassembly, including:
Girdle bolts
head bolts
bearings
rods
pistons and rings
head gasket
timing chain
For the most part, they are all parts that would normally be replaced during a rebuild, hence the reason they were disposed of.
I have a completely new set of OEM valves, springs, locks and seals from a factory new head that I will throw in if wanted to replace the damaged valves of the core.
Local pick up from Chicago land area only. Will not ship. Asking $500.
Also;
I have a set of GMPP pistons, brand new in the box. Asking $400. These pistons require the use of the LSJ rods. Would make a perfect addition to the above block build, giving a safe rotating assembly to over 400 HP.
Old Jan 31, 2007 | 07:11 PM
rally's Avatar
Halfcent i'll bump this for you because I know you've had those pistons on your hands for well over 6 months now
Old Jan 31, 2007 | 10:01 PM
TCarter's Avatar
I MIGHT be interested...i'll let you know.
Old Apr 10, 2007 | 11:14 PM
Dustin's Avatar
Still got this? Mine might be toast. Might go for the piston/core combo.
Old Apr 10, 2007 | 11:30 PM
Halfcent's Avatar
I'm old school
Still got it. But you are in Florida, and I don't want to ship it.
Old Apr 13, 2007 | 09:14 PM
biohazard's Avatar
Get low
damn i rlly wanna buy this but i dont have the cash, i need to finish more of my projects, bump for u
Old May 26, 2007 | 03:35 PM
Halfcent's Avatar
I'm old school
Sold!
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
