FS: Aeroforce Interceptor Gauge 2.2 2.4
plugs directly into your OBD2 connector and it basically scans your sensors and give u a readout of two at a time it has like 15+ different readings....ex. oil pressure,tranny temp,IAT,knock retard,mpg,a/f,TP percentage...also has two programmable LED shift lights
they cost 240+shipping and thats the cheapest i could find....RPM
MPH..Intake Air Temperature pre intercooler..Intake Air Temperature post Intercooler..
Mass Air Flow Sensor.. Frequency Mass Air Flow Sensor (lb/min.)...Engine Coolant Temperature
Injector Pulse Width..Long Term Fuel Trim...Short Term Fuel Trim..O2 Sensor Voltage..Manifold Pressure in PSI (Boost pressure)..Supercharger Inlet Pressure..Ignition Advance..Knock Retard..
Engine Run Time..Battery Voltage..Throttle Position Percentage..Engine Load..Instantaneous fuel economy..Horsepower..Analog input #1..Analog input #2..
Sl0wbaltSS
Nov 21, 2018 11:11 PM
