Fs/ft: Aeroforce interceptor
Old Dec 14, 2009 | 11:20 PM
rkenny97's Avatar
I GOT FOR SALE A INTERCEPTOR GAUGE BOUGHT LESS THEN A MONTH AGO IT GREAT I LOVE IT, BUT ITS JUST NOT ME TO MUCH ON ON LIL THING. LOOKING TO GET 165 OBO. OR TRADE FOR LSJ COBALT PARTS. *(REALLY WANTING A METH KIT)*, if wanna get in contact for a trade or purchase other than here feel free to txt me. (615)663-7674, thanks ronnie.
This amazingly powerful 2 1/16" (52mm) gauge provides real time information allowing you to diagnose problems, measure performance, fuel economy, and read and clear trouble codes. It does it all and looks great too! Simply plug into your diagnostic port to display just about anything you'd want to know about your vehicle.
-Dozens of critical parameters available for every supported vehicle. Can view 2 to 8 at a time in large, easy to read numbers without touching the gauge.
-Record and play back data on gauge, no need for laptop or other device
-Accepts 2 additional sensors without requiring any additional equipment unlike other copycat products. Allows you to read such things as air/fuel ratio, EGT temps, etc. that are not on the vehicle from the factory.
-High intensity warning lights can be programmed to indicate unsafe vehicle operating conditions.
-Integrated shift lights.
-Available in numerous configurations allowing you to match or customize your dash!
Displays the following information:
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
Old Dec 14, 2009 | 11:53 PM
ecotecon18s's Avatar
dibs... PM'd...
Old Dec 15, 2009 | 01:15 PM
rkenny97's Avatar
pm replied
sold
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
