For Sale FS: Option B/w bracket and meth pump/check valve
Old Feb 15, 2014 | 01:27 PM
Contact: Post/PM
First to pay gets the parts.
Shipping is uncluded in the prices for 48 states. Canada, we will work with you.
Option B: Comes with the expansion tank, bracket, hose and fitting from top of h/e to tank, as well as the line going from the tank to the endplate, which i am also including my previously used setup for an easy swap.
This means the two lines coming from the dual pass endplate, into a y-fitting with one line that routes perfectly to the option b.
So really, this is a full kit. Only thing missing is the two bolts that hold the bracket on, which i might find or you can easily source your own. and really, they are barely even needed.
Since its used, and the feed line from the heat exchanger is all yellowed and crappy looking, i'm asking for 95 shipped. There is over 130 worth of parts to properly do this on your own and unless you buy powells setup you don't get y fittings.
the line and fitting that goes to the top of h/e
the leftmost end goes to the top of the dual pass endplate. the next one goes to the bottom end. the 2nd from the right (long hose) goes up to the top of the bumper support and around the belts and pulleys to the tank. the rightmost end feeds into the pump
And here's a Devils Own meth pump.
Off my progressive injection setup; this pump will work for any setup and can handle atleast a 10gph nozzle.
It's a 250 psi pump that i used for ~~25000 miles. pump never failed, but my controller might be fritzy since it sprayed full one time when it wasn't supposed to. if interested i will pull the controller too. Perhaps it was install error, perhaps the controller is messed up somewhere. Not sure.
I spraypainted it gunmetal silver to protect it from rust. Also comes with a bracket of some sort you can work with.
Also giving you a free check valve and a good couple feet of line with the pump.
Not sure what to price this at, lets say 75 obo
Old Feb 15, 2014 | 02:36 PM
Gmoney06's Avatar
So want that option b setup. Come on ebay stuff sell faster. If you still have it when my stuff is all sold I'll hit you up.
Old Feb 15, 2014 | 03:04 PM
ok thanks
Old Feb 15, 2014 | 03:28 PM
Sunburst_SS's Avatar
not to get off topic....but why are you selling?? Not using this stuff in the new build I assume?
Old Feb 15, 2014 | 03:31 PM
yeah, the zzp stealth heat exchanger does not have a thread on top to use the option b with, since you can vent air from the fill cap.
i bought a different meth kit to do a different setup with.
Old Feb 15, 2014 | 03:38 PM
oh ok, good deal.....I just bought all that stuff with some ottp stage 4's. Good luck with your build, and sale!
Old Feb 15, 2014 | 04:19 PM
iToastie's Avatar
You PM's inbox is full -_-
Old Feb 15, 2014 | 04:33 PM
06cobaltncng's Avatar
bump for adam!
Old Feb 15, 2014 | 06:50 PM
Opt b sold
Old Feb 15, 2014 | 09:48 PM
Gmoney06's Avatar
Opt b sold
Ah, of course it is. That was an awesome deal.
Time to start piecing mine together.
Old Feb 19, 2014 | 01:38 PM
yeah i thought the price was right. hope itoastie likes it!
pump still for grabs. price is obo
Old Feb 25, 2014 | 02:20 PM
bump for meth pump
Old Feb 25, 2014 | 02:32 PM
Staged07SS's Avatar
Administrator
Administrator
You can have zzp weld a fitting for opt. b on the stealth.
The stealth heat exhanger will still not provide a constant bleed like opt. b.
You should hang on to it.
Old Feb 25, 2014 | 02:33 PM
yeah i know, opt b is already gone though. i may grab a stock filler neck to try and help instead
Old Feb 25, 2014 | 02:44 PM
Staged07SS's Avatar
Administrator
Administrator
Honestly, I would just get the bung welded on, and keep opt. b.
The stock filler neck is a waste of time.
It's your call man, but it's silly to remove opt. b if you already have a kit.
Old Feb 25, 2014 | 03:13 PM
i don't have it though
maybe we'll weld the bung in and throw an opt b at it later down the road
Old Feb 26, 2014 | 07:07 AM
Staged07SS's Avatar
Administrator
Administrator
Sorry, missed that it sold all together....
Old Feb 26, 2014 | 08:07 AM
All good buddy!
Old Feb 26, 2014 | 08:14 AM
blueLNFftw's Avatar
I would at minimum weld in the Option B bung now and put a cap in it so later when you go to add it you do not have to put the car down and pull the HE to do it.
You should have kept this. Everyone I know that bought a stleath ended up getting the bung put in. ZZP should offer it.
Old Feb 26, 2014 | 10:28 AM
i hear ya man
Jan 12, 2016 12:01 AM
Trav3480
Oct 1, 2015 08:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
