Wanted LNF turbo (K04)
Old Aug 20, 2009 | 11:13 PM
JsavageSS/TC's Avatar
LNF turbo (K04)
Hey guys... So... My turbo blew. No mods done... water/meth injection.... not used in a year... no tune.... GM wont warranty it so I need one. Someone hook me up please... this is my only car
Old Aug 20, 2009 | 11:14 PM
umrdyldo's Avatar
that sucks cause a few people had that happen.
BLAZIN07SS's Avatar
I'm too JDM for you
PM Negrita SS. he might have his stock one off already. just replaced under warranty
Old Oct 4, 2009 | 02:59 AM
mkriebs's Avatar
You still looking for one?
Old Oct 5, 2009 | 02:16 AM
Yes! lol
Old Oct 5, 2009 | 02:18 AM
mkriebs's Avatar
I have a brand new one... would be willing to part with it for $600 shipped... Its never been on a car, no oil ever through it, its BRAND NEW. Retails for a lil over $1300...
Old Oct 5, 2009 | 01:08 PM
pt5457balt's Avatar
gmpartsdirect.com has them for $980'ish, assuming they're in stock.
Old Oct 12, 2009 | 03:38 AM
mkriebs's Avatar
Still interested???
Old Oct 13, 2009 | 01:59 AM
I am still interested... I currently have the turbo off and I think I am going to rebuild it. Spools are still good and in tact. I think I blew a seal and I think the bearing is messed up, housing is good but we snapped the shaft when we were going to take it apart. So I think I need to save money and just rebuild the turbo. Or get a good USED one. What do you guys think?
Old Oct 13, 2009 | 02:25 AM
mkriebs's Avatar
If its rebuildable, consider the big wheel upgrade! I know it will flow alot better with that new wheel, plus, you basically get a rebuild in the process. My shop can do it for $999. I know its a tad expensive, but its an excellent upgrade. Its an option at least. Or, you could get my brand new one for $600, lol. I am not sure how much a rebuild will cost, and how reliable it is, but thats definitely the most viable option.
Old Oct 17, 2009 | 11:45 PM
I just bought a brand new turbo on ebay for $405! Guy said he had bought it for a spare incase his blew. Anyone on here that person? I should get it in about a week.
Anyone know who would want to buy my blown turbo? Housing is bad, all it needs is a new bearing and shaft....
Old Oct 17, 2009 | 11:52 PM
Black08SSTC's Avatar
would this be a good candidate for the big wheel upgrade??
Old Oct 18, 2009 | 02:00 AM
mkriebs's Avatar
If the housing is cracked, it MIGHT be able to be welded up. If he means housing is bad, as in worn to **** from the bearings, then it most likely will not be able to be used with the big wheel, since the big wheel still uses the same center section.
Any pics of said damage?
Old Oct 18, 2009 | 01:52 PM
I havn't been able to take it apart... I know its the bearing because of play in the shaft and turbines.... oil everywhere including in the intercooler. I am going to atempt to take the turbo apart and look it over, I then will take pics and post them. From what i can tell, the housing is not cracked anywhere except for the hot side where its split and connects to the DP... 3 small hairline cracks, thats normal though i think.
I had to take the head off to get the turbo off, I forgot to tie up the timing chain, so is there any special way to time the LNF? I figured I would do it by put the #1 cylender to TDC. But then I am confused because all I know is old school with a distributer.
Is it safe to flush out the intercooler with purple power and water? Or should I just use gas?
Old Oct 18, 2009 | 01:55 PM
pt5457balt's Avatar
wait, you took the head off to get the turbo off???????
Old Oct 18, 2009 | 01:57 PM
Yes, I am working with tiny jack stands, plus a couple bolts were a pain in the ass to get to, so I said **** it and took the head off. Was way easier that way
Old Oct 18, 2009 | 01:58 PM
mkriebs's Avatar
As for the turbo... it depends on the crack, but yes, they are pretty normal. We, at WERKS will heat the housing up and weld the cracks, but its not as good as using a brand new turbo for the big wheel upgrade.
Timing the car... I am not familiar enough to say anything.
And for the intercooler, I would just clean out as much oil as possible, but I wouldn't use anything too harsh as the core is aluminum. It won't hurt the engine to take in a little bit of oil.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
patooyee
Oct 1, 2015 01:07 PM
