Wanted Passenger Brembo Caliper
Old May 21, 2014 | 12:05 AM
PyroMechanic's Avatar
WANTED
Passenger Brembo Cobalt SS brake caliper.
Bought a used set from a guy about 2 months ago and he gave me one of the calipers with partially stripped bleeder screw threads. Spent so much money on the brake system, if anyone has a passenger one to let go for cheap, pleaseeee pm me.
I cant catch a break.. Within the passed 2 months, had to replace/fix a flat tire, tie rod end, both sway bar endlinks, struts, shocks, strut mounts, both front hubs, control arm bushings, fuel pressure regulator, fuel pump, return fuel line, rotors, cv axle, new battery, had to buy new sway bar endlinks a second time, and now the caliper's stripped. Oh, and get an alignment twice. Someone pleaseee help so I don't have to spend a fortune for another caliper. My caliper has 8k miles on it and all that is wrong is the damn threads. Cant tap because I need to use the same bleeder screw since the bottom is tapered.
Old May 21, 2014 | 02:02 AM
Biohazd's Avatar
Talk to Mongorat. He has some used calipers for $250 a pair.
Old May 21, 2014 | 02:05 AM
ItalianJoe1's Avatar
If you google bleeder screw repair kit, they make them where you can tap it for a larger adapter and then use the standard screw to still seal on the taper as factory. If you don't mind the ugly appearance anyway.
Old May 21, 2014 | 11:47 AM
Tried a screw repair kit, didn't work, would need a bigger tap. And I am already talking to mongo.
Old May 21, 2014 | 12:15 PM
Dan_G's Avatar
Front Brembo Caliper LH 25900763 (ACDelco 172-2484) - $132 (amazon)
Front Brembo Caliper RH 25900764 (ACDelco 172-2485) - $136 (amazon)
jmdubose202
Dec 29, 2015 05:06 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
