For Sale sub, amp, cap and wire
Old Sep 7, 2010 | 10:56 AM
kristen's Avatar
everything you need for a sub and amp!(items are in great shape)
200 plus shipping obo
Premier™ Mono Power Amplifier with 800 Watts Max. Power (with control)
Pioneer TS-W256C 800 watt sub.
Rockford Fosgate - 1-Farad Capacitor
Tsunami 4 Gauge/850 Watt Amplifier Install Kit with MANL Fuse Holder AMP850BL, Blue
AMPLIFIER
Monoblock Amplifier
RMS Power Rating:
4 ohms: 250 watts x 1 chan.
2 ohms: 360 watts x 1 chan.
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
2 Channel Gold RCA Inputs
Built-in Crossover: Selectable LPF
CEA-2006 Compliant
PWM Regulated MOSFET Power Supply
Bass Level Control, 0 - 12dB
Input Level Control Hi-Volt (200mV ~ 6.5v)
CAP
Improves sound quality- cleaner mids and highs
1 Farad
16 volt-20 volt peak
1/0 & 4 Gauge power & ground terminals
Digital volt meter, blue display
Platinum plated
Solid brass top helps reduce stripping
Low ESR (Equivilent Series Resistance
SUB
Woofer Cone Material: Composite IMPP cone using Interlaced Aramid Fiber
Surround: Wide Roll, Three-Layer Fiber Woven Radial
Voice Coil: 4-Layer, Long Voice Coil
Voice Coil Bobbin: 12 Slit Aluminum
Damper (Spider): Y
Projected Pole Yoke with Vented Pole
Magnet Construction: Double Mass High-Power
Gasket: Molded
Specifications
Watts MAX. Music Power: 800 Watts
Watts Nominal Power Handling: 350 Watts
Frequency Response: 18hz ~ 2.5kHz
Sensitivity: 87dB
Ohm Rating: 4
Recommended Enclosure: 1.0 Cubic Feet
Accessory Grill: UD-G255
Old Sep 15, 2010 | 11:28 AM
kristen's Avatar
200 obo want it gone
Old Sep 15, 2010 | 02:10 PM
Travs03fire's Avatar
free bump....cap is generally used to store power for when the harder bass hits...doesnt really improve your highs or mids....just give the amp that little extra juice when the harder notes
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
