Who has a pulley puller that I can use?
I have on you can use but I really think you're going to jack the pulley up (seen it before). As far as installing the new hub....pulley puller won't help....maybe a modified harmonic balancer puller/installer. A press would be your best bet. let me know.
ZZP or INTENSE Racing has a couple good set-ups...probably the way to go
I have one you can BORROW, but I require a $125 deposit through paypal, $100 of which will be refunded to you and $25 of which is used for shipping to you with a return label to ship back to me. You break it, lose a part, or anything then it's yours to keep!
Wasn't trying to be negative or anything. The pulley puller I have has small claws at the end...no plate or anything. Well I guess that's what I get for free. But I have a harmonic balancer puller kit that may be considered a "pulley puller".
left pulley puller as I know it......right harmonic balancer puller/installer kit (could be considered a pulley puller)
BTW StreetDreamz that's a pretty good/fair deal.
Last edited by M88ArRamadi; Apr 17, 2009 at 11:19 AM. Reason: Automerged Doublepost
Yeah, that is not the correct style puller to remove a pulley from an roots style supercharger with a pressed on pulley. The proper ones have a big, thick metal plate that goes around the whole back side of the pulley and pulls evenly the whole way around. I can see how you could screw up a pulley using a two or three jaw puller. Two or three jaw pullers are used for like seperating ball joints.
Why keep the stock pulley anyways? A three prong puller will work just fine. I've done 5 stage II installs this way with no problems to the SC. In some cases the pulley is no longer usable though.
patooyee
Oct 1, 2015 01:07 PM
