Wtb: Stock Block! 2.0l Only!!! Please Help>
Old May 24, 2007 | 04:41 PM
06noscobaltss's Avatar
Hey I need a new block from a 2.0L. Mine blew yesterday and I cracked the block and sleeve on the 4th cylinder. Anyone have one? It needs to have perfect or near perfect sleeves and no block damage! Please let me know if someone has one! Thanks
Old May 25, 2007 | 03:10 AM
bump!
Old May 25, 2007 | 03:12 AM
sunfirejoe's Avatar
if u dont mind me asking how did ur block crack :S
Old May 25, 2007 | 03:15 AM
too much pressure, too much heat, or both of those problems. I cracked the #4 Piston sleeve and cracked the #4 cylinder also. Nice big open crack down the whole thing. but bump as I need to get a stock block asap.
Old May 25, 2007 | 06:33 AM
06blackSC's Avatar
with your mods, maybe you should look into the gm race block....
just a suggestion.
Old May 25, 2007 | 11:05 AM
just a suggestion.
someone correct me if im wrong but isnt that a 2.2L Race block not a 2.0
Old May 25, 2007 | 12:00 PM
RaineMan's Avatar
The block is the same... it's the stroke of the pistons that makes the displacement... I believe the bore size is the same... the LSJ is just destroked.
Old May 25, 2007 | 12:06 PM
Ok so what Im hearing is I can buy that Race Block and all the 2.0L internals and such will fit in no problem?!?
Old May 25, 2007 | 12:34 PM
chipsgt's Avatar
I believe that is correct, but let someone else confirm.
Old May 25, 2007 | 12:35 PM
Can anyone else confirm this!?
Old May 25, 2007 | 12:56 PM
RaineMan's Avatar
Try messaging Tom from CED... or asking around with some of the parts/tech guys that are on the forums... they can give you a better answer than what I can.
Old May 25, 2007 | 10:12 PM
ok i sent out Pm's but bump for someone selling a stock block... ANYONE???
Old May 25, 2007 | 10:13 PM
HackAbuse's Avatar
There was a guy here selling a 2.2 complete engine for some cash, idk if the block is identical though. He was looking for like $200
Old May 26, 2007 | 12:11 AM
spaz's Avatar
https://www.cobaltss.net/forums/parts-66/ecotec-l61-core-engine-24851/
Is Wheaton near Chicago?
Old May 26, 2007 | 02:24 AM
06blackg85ss's Avatar
**** mine won't be available for a few weeks sorry man
Old May 26, 2007 | 01:06 PM
BUMP I need a block in the next week or so. Anyone know where I can get one?!?! PLEASE?!
Old May 26, 2007 | 01:22 PM
you can use the 2.2 block, just have to swap the reluctor ring off the crank
Old May 26, 2007 | 02:56 PM
sunfirejoe's Avatar
also make sure u tap your oil piston sprayers(i dont the technical name)
Old May 26, 2007 | 03:23 PM
HackAbuse's Avatar
https://www.cobaltss.net/forums//sho...t=53682&page=1
Buy his, take the block, then part out the rest of it and you'll probably break even man
Old May 27, 2007 | 12:53 PM
I read through that post and I will not buy that motor! He doesnt even know what the damage is cause he has never taken it apart. so that one I will not buy. Thanks for finding it though.
AND BUMP FOR A 2.0L!!!
Old May 27, 2007 | 11:54 PM
Blurred Vision's Avatar
I have a 2.0 block, with out the pistons,and rods. only thing wrong with it is that there is part of a piston melted to the sleave on #4.
Old May 28, 2007 | 12:03 AM
Psykostevo's Avatar
They sell a 2.16L ~800hp turbo motor for our cobalts. You can order it through GM I believe, just not through the dealerships.
Old May 28, 2007 | 12:11 AM
AMG_Passion's Avatar
The 2.2 race block will work with 2.0 internals.
Old May 28, 2007 | 12:51 AM
WopOnTour's Avatar
Something like this is your best bet. If it's got a damaged cylinder, you can have a dealer put a new liner/sleeve in. (they have the special tools to do so) You dont want the GMPP race block OR a 2.2 for that matter- too many differences and issues requiring significant work-arounds
Wop
Old May 28, 2007 | 06:07 PM
