WTB Upper Engine mount
Old Jul 29, 2008 | 01:27 PM
Rodimus_Prime's Avatar
Show me what ya got!
Old Jul 29, 2008 | 03:45 PM
Doc's Avatar
Doc
do you mean the stock one for the passenger side..?
Old Jul 29, 2008 | 04:03 PM
BlkWdoSS's Avatar
yea which mount are u interested in? im getting the turbo tech one and i will sell you my stocker if thats what you want
im looking for an aftermarket one but yea the one on the passenger side
Old Jul 29, 2008 | 04:13 PM
steddy2112's Avatar
You should get the trans ones too...because if you don't...one month later you will be back at square one.
Old Jul 29, 2008 | 04:15 PM
hows that
Old Jul 29, 2008 | 04:22 PM
steddy2112's Avatar
Well the engine still has to move, and honestly the trans bushings take most of the movement/abuse.
Your stockers will get worn out and have no support.
It is just like if you you go trans bushings, and solid upper...eventually the a-arm bushings will wear out(at a much slower pace than if you just went with the solid upper) and cause tomfoolery.
Old Jul 29, 2008 | 04:25 PM
ColeJJones's Avatar
Bannned
dont ever install the motor mount without the tranny mount. and vise versa
Old Jul 29, 2008 | 04:26 PM
ls1fbody's Avatar
Haz l33t wheelz.
talk to TTR, there are guys that are holding up the GB, jump in on it!
Old Jul 29, 2008 | 04:27 PM
steddy2112's Avatar
I had it on the old car...and twas ****.
DON'T EVER TRY TO GO BACK TO STOCK UNLESS YOU HAVE A LOT OF PATIENCE THOUGH.
Old Jul 29, 2008 | 05:03 PM
Doc's Avatar
Doc
who told you this..??
I've had a poly motor mount for almost 3 years without anything else.
Old Jul 29, 2008 | 05:05 PM
steddy2112's Avatar
I guess it would really matter of how hard you are on your car as well...
Old Jul 29, 2008 | 05:07 PM
sikcobalt's Avatar
Agree, I have had mine for over a year now and not one problem. Who said you have to have both in?
Old Jul 29, 2008 | 05:10 PM
Doc's Avatar
Doc
I've had more than 180 passes on the 1/4 if that's not beating the **** outta it, I dunno what is.
Old Jul 29, 2008 | 05:16 PM
steddy2112's Avatar
I have had read people having issues but now that I hear this...sweet deal
I will throw mine in my TC
Old Jul 29, 2008 | 05:21 PM
Doc's Avatar
Doc
are they the same on the TC..??
I didn't look real close..makes sense that they wouldn't change it.
Old Jul 29, 2008 | 05:23 PM
steddy2112's Avatar
Exactly the same.
Our trans bushings are not the same as on the F23 though...I dunno what a stock SS/SC bushing looks like.
Old Jul 29, 2008 | 08:10 PM
ive heard that using the poly mounts on the tranny cause the mounts to break off the F35 casing since the material is weak
Old Jul 29, 2008 | 08:57 PM
TurboTechRacing's Avatar
False info, The stock castings are strong enough, 1 or 2 installed them incorrectly and when they pressed them in they cracked it, if you do it correctly and press them in square, you will never have an issue.
The Turbo Tech Racing Solid mount has been rated #1 on the forums for years... Best one out there, as members have had other mounts and then switched to the TTR and stated it is hands down the best out there (took us over a year in R&D to design this, making sure it was the best)
Old Jul 30, 2008 | 06:22 PM
I guess theres only what 2 choices out there TTR and ZZP?
Old Jul 30, 2008 | 06:29 PM
Doc's Avatar
Doc
I have a set of ZZP billet poly mounts I haven't installed.
Old Jul 30, 2008 | 09:18 PM
reallllllly.....which ones were they
Old Jul 30, 2008 | 09:20 PM
The tranny ones, most likely.... IMO they dont offer anything to benifit... If they did we would manufacture them. The ZZP are aluminum machined mount housings, the stock ones are cast steel.... Stock are more than strong enough. All that matters is the material in side the mount is stiffer for less movement.
The prothane inserts are just as good (SEMA product of the year a year or two back). Just cost a lot more for the ZZP.
Old Jul 30, 2008 | 09:23 PM
"If you make that to stiff with your kind of power you can say bye bye to the tranny. The tranny needs to move and flex a bit, trust me."
Thats what ive been told and I can understand it to some point any other opinions on this?
Old Jul 30, 2008 | 09:25 PM
Doc's Avatar
Doc
these
