4x4 Rock Buggy TC 2.4 Build
Old Mar 14, 2016 | 03:30 PM
  #326
YelloEye's Avatar
Since when does 1x2.4 equal 4.8?
That's what I get for not pointing out that 1 bar (14.5psi) on the boost gauge means the car is actually ingesting 2 bar (28psi) absolute.
Originally Posted by patooyee
I thought the same but 1 bar boost = 2 bar absolute and 2.4 * 2 = 4.8. So I figured that's what he meant.
18 psi boost = about 2.25 bar absolute. 2.25 * 2.4 = 5.4L. So on that table 3" should be OK.
I think the stock turbo outlet is 3.5" though. Why wouldn't I do that? I mean, nothing wrong with going too big in a turbo system, is there? I have tons of 3.5" pipe laying around from previous V8 builds. I've never worked with 3" so I don't have a single inch of that.
This guy gets it.
You can run 3.5", won't hurt anymore than just running an open turbo really. Less back-pressure is better. Your only hang up is space, if you can make 3.5" work and have a ton laying around I'd just use it.
Old Mar 14, 2016 | 09:34 PM
  #327
I understood what you meant but what you said and what you meant were two different things lol
Old Mar 15, 2016 | 03:46 PM
  #328
YelloEye's Avatar
Re-reading it yes, I see how that could get mixed up. Fixed that now lol
Old Mar 17, 2016 | 01:44 PM
  #329
patooyee's Avatar
Knuckles are on. On Sunday I'm going to go draw up a rough block to match the engine / trans and start modelling a chassis around it.
Old Mar 26, 2016 | 04:01 PM
  #330
patooyee's Avatar
Since I finalized axles I started taking measurements and obsessing over the chassis. So far this is where I am at:
Just kind of moving the seat, drivetrain, and everything around to achieve acceptable ride height, driveline angles, and chassis clearance. I can also print this up from a side view and start drawing ideas for what I want the chassis to look like.
Old Apr 2, 2016 | 08:21 PM
  #331
patooyee's Avatar
CAD work on the chassis is coming along nicely. I'll post pics soon. It would be nice to be able to move my seat back a few inches if at all possible though. To do this the alternator has to move to the other side of the engine or down low where the a/c compressor was. Does anyone know of any options for this?
Old Apr 3, 2016 | 12:30 PM
  #332
Im sure you can make a bracket for it but you may end up with a custom belt then
Old Apr 3, 2016 | 12:31 PM
  #333
patooyee's Avatar
You're not aware of a different application that places the alternator somewhere else then?
Old Apr 3, 2016 | 01:01 PM
  #334
Sharkey's Avatar
the alternator on all the ecotecs in in the same place. cant think of an other application were you would bee to move the alternator either
Old Apr 3, 2016 | 01:02 PM
  #335
patooyee's Avatar
Thanks. That's what I was needing to know.
Old Apr 11, 2016 | 08:39 PM
  #336
patooyee's Avatar
I've got most of the chassis laid out in SW now. Shouldn't be long before I'm bending and rolling tube:
Old Apr 11, 2016 | 11:50 PM
  #337
Not low enough
Old Apr 11, 2016 | 11:58 PM
  #338
patooyee's Avatar
Not low enough
Haha. In comparison to a cobalt?
Old Apr 12, 2016 | 08:31 AM
  #339
If you can see my sig youll understand haha
Old Apr 12, 2016 | 08:41 AM
  #340
patooyee's Avatar
Oh yeah, no sigs in the mobile version.
Old Apr 12, 2016 | 09:04 AM
  #341
So how long until you start cutting tube? What material are you using?
Old Apr 12, 2016 | 12:55 PM
  #342
patooyee's Avatar
1.5 x .120 DOM with 1.5x.188 mixed in strategic places that will see hard hits from rocks. I've still got a lot of CAD work to do. I've got to design the suspension and brackets as well as create a compartment for my legs and pedals. I want to put as much into CAD as I can just as an exercise to learn. Radiator, intercooler, brackets, fuel cell, etc. Maybe start cutting and bending in a month or so.
Old Apr 12, 2016 | 01:16 PM
  #343
definitely good to have it planned out rather than just throwing ot together like i normally do
Old Apr 12, 2016 | 02:12 PM
  #344
YelloEye's Avatar
Not a structural engineer, just my 2˘.
I don't like the space the driver is supposed to occupy, cage comes way too close to the head and is at a really shallow angle to the front. I would think the driver's A-pillar would be relatively easy to mash into the driver's space. Is the top crossbrace and roof section supposed to be level with the ground? If it's not I think a helmet would basically sit on the back side of the X section there.
Old Apr 12, 2016 | 03:37 PM
  #345
patooyee's Avatar
It's not done yet, I just posted a pic now because you can see the overall look.
There will be an additional a-pillar there to help support the primary, which is more than most buggies get.
The roof is not supposed to be level to the ground.
The size of that seat is deceiving. I didn't bother modeling it super-accurately since there really is no good way to do so. So I just modeled it to max dimensions. My head doesn't come very far above the top of the seat in reality. (It is a tall seat.) The general rule of thumb is to leave 6" above the top of your helmet, which I did in my last rig. The problem with that is that it doesn't account for how much these suspension seats sag once they're broken in. My last buggy I used that rule but then after the first few trips out the seat sagged 6" and the interior suddenly became cavernous. I could have made the roof 6" lower in the end. So on this one I've cut it close as best as I can measure myself in the drawings. That being said, I haven't had anyone around to actually measure me in the seat yet. I've just been going by the best dimensions I could possibly take of myself while sitting in it, which is very difficult. As such, I've left the roof height easily adjustable for when I do have someone to measure me. I've got someone coming to the shop tomorrow to have me weld some intercooler pipes for him. I'm hoping to get him to measure me with my helmet on while he's there.
Old Apr 14, 2016 | 01:10 AM
  #346
YelloEye's Avatar
If your helmet sits where you say it does relative to the seat top then I think you have a good design with that extra A-pillar. I was just picturing a much larger person in that seat with its dimensions
Old Apr 26, 2016 | 08:37 PM
  #347
patooyee's Avatar
Anyone have an advice on how to properly size an air to air intercooler?
Old Apr 26, 2016 | 09:39 PM
  #348
cluelessk's Avatar
I was always under the impression you don't want hard bends in your roll cage. Especially the section surrounding the driver.
Old Apr 26, 2016 | 09:41 PM
  #349
patooyee's Avatar
Every rock buggy on the planet is in violation of that rule then.
Old Apr 26, 2016 | 09:58 PM
  #350
Based on the HP Or flow rating given by the manufacturer
