accident with balt
Old Feb 18, 2009 | 08:55 PM
va thunder's Avatar
Unhappy accident with balt
i know it isnt the best pic, but my cell phone was all i had with me. I had to swerve around another car and i hit the median and a tree that was in the median. What a bummer.
Old Feb 18, 2009 | 08:56 PM
srowler9's Avatar
you hurtied your car.
Old Feb 18, 2009 | 08:58 PM
mrsilent13's Avatar
airbags did not go off?
glad your ok....i had a similar thing happen to me....not a tree but a pole
check my images you will see
Last edited by mrsilent13; Feb 18, 2009 at 08:58 PM. Reason: Automerged Doublepost
Old Feb 18, 2009 | 09:00 PM
va thunder's Avatar
i was really surprised my airbag didnt go off, i hit the tree at about 30mph
Old Feb 18, 2009 | 09:05 PM
mrsilent13's Avatar
are you serious...both of mine went off and i was doing about 30-35...shattered my window and everything....
and here is after i started to rebuild and see what kind of damage was done
Last edited by mrsilent13; Feb 18, 2009 at 09:06 PM. Reason: Automerged Doublepost
va thunder's Avatar
my passengers airbag didnt deploy either. Wish i could find out why.
SSdan's Avatar
Sensor is located directly in the middle of the rad support.
He hit just off to the left.
Old Feb 18, 2009 | 09:07 PM
mrsilent13's Avatar
well look at it this way....it will be cheaper to repair cuz airbags are expensive
Old Feb 18, 2009 | 09:10 PM
drop-n-destroy's Avatar
Suck dude. Hope you are OK. Airbags don't deploy just because of any hit. Depends where it got hit as the car has multiple sensors and will activate if they hit that targeted sensor at the right speed and angle. your passenger airbag did not deploy because I assumed there was no one with you and the airbag for was deactivated.
Anyway
Is it gonna get fixed?
Old Feb 18, 2009 | 09:51 PM
blackbird's Avatar
The newer cars have sensors in the passenger seat and will deactivate when not occupied or if there is a child or infant seat placed in the seat. The airbag system also doesn't just go off any time you hit something and was probably working exactly as intended. The safing (impact) sensor measures the impact crash pulse energy and if the airbag controller determines the crash energy is not high enough to create a high change in velocity (Delta V) it won't fire the airbag(s). Also if the impact is at an angle or the car rotates the forces may not be applied at an angle that the airbags will fire and be able to help. Depending on the impact the airbag controller can also use a combination of the seat belt pretensioners (if equipped), airbag(s), or both.
Be thankful that you weren't injured which could still happen if you had airbag deployment or not. Also because your airbags didn't go off there's a better chance your car won't be totaled. You may not want to get it repaired and get the car back, but if the insurance writes it off, in most cases you'll usually lose money when all is said and done. If the frame rail wasn't severely damaged I'd bet you have $5-6k in damages and depending on how much they value the car at, is probably under the limit to total it. If the airbags would have went off when they weren't apparently needed that damage figure would have went up quite a bit. New airbag components are expensive.
Old Feb 18, 2009 | 11:05 PM
va thunder's Avatar
thanks for all the responses! I DID have a passenger in the car with me at the time, but we are both OK. I heard from USAA today that they are thinking it will be fixed, but have to cut the front end off to make positive that there isnt anymore engine or frame damage that was seen already. The adjuster said it was around 7K of damage from what he has seen.
Old Feb 19, 2009 | 04:52 PM
revhigh18's Avatar
that will buff out no worries
06MetallicBalt
Jul 20, 2025 08:47 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
grampss
Sep 27, 2015 08:51 PM
roth
Sep 26, 2015 12:16 PM
