Devil's Own Progressive Kit Installed! w/ Pics!
Old Apr 13, 2008 | 10:50 PM
ColeJJones's Avatar
Bannned
another bad ass install by myself/stryder/ssmokin. this was put on Matt's car. the install was simple and easy to do. this DOI kit is pretty sweet. here are pics of the install. hope you like!
we mounted the pump behind the headlight. sleeper style.
close up
as you can see, Matt used his own bolts. the tank wont be able to bolt up against the frame anymore. but the other two bolts that hold it down are more than enough to keep it stable and in place.
here is the pump installed with the headlight bracket in place.
close up
and here is the nozzle that is tapped into the cobalt addiction spacer. let me tell that this is spacer = ****.
another view
better view
here is the controller mounted on the inside of the car. check out the hella cool ass pedals and 7" dvd screen. pimpin
finished display. are you stock? sleepa
Matt has no comments
Old Apr 13, 2008 | 11:11 PM
VolklSkiier's Avatar
NICE... this is exactly what i was planning on doin, except i like your mounting better than my plan, I might have to borrow that idea.
Old Apr 13, 2008 | 11:16 PM
ColeJJones's Avatar
Bannned
yea i seen your thread on where you wanted to put it. almost on the right idea
Old Apr 13, 2008 | 11:17 PM
kwest's Avatar
dude how did you get the dash pieces where the ac controls are painted black? and what did you use to get the red painted pieces to look that glossy?
Old Apr 13, 2008 | 11:18 PM
jimbos'ss's Avatar
so what turned out to be the issue with the controller?
Old Apr 13, 2008 | 11:19 PM
ColeJJones's Avatar
Bannned
gonna have to ask Matt about the black controls. and for the glossy red, mine are like that... i thought everyones were like that
Old Apr 13, 2008 | 11:22 PM
stryder's Avatar
issues with the controller remain. and the dash pieces were painted with gm paint and some clear coat.
Bodychecker628's Avatar
mine are semi-glossy white and red gunna re coat them with more gloss soon
Old Apr 13, 2008 | 11:23 PM
jimbos'ss's Avatar
so the whole thing is not working right now?
Old Apr 13, 2008 | 11:24 PM
ColeJJones's Avatar
Bannned
what gives?
it works for a little bit then i guess it shuts off
Last edited by ColeJJones; Apr 13, 2008 at 11:24 PM. Reason: Automerged Doublepost
Old Apr 13, 2008 | 11:26 PM
Mnatvyc1223's Avatar
nope, non-SEMA show cars have the stock silver...
what gives?
is there a ground wire? and if so, is it grounded properly?
and if it's the controller then i have no idea
Last edited by Mnatvyc1223; Apr 13, 2008 at 11:26 PM. Reason: Automerged Doublepost
Old Apr 13, 2008 | 11:54 PM
ColeJJones's Avatar
Bannned
lol, my bad.
Matt says when his **** starts spraying his afr jumps to the mid 15s... wtf! that makes no sense at all. should be rich if anything
Last edited by ColeJJones; Apr 13, 2008 at 11:54 PM. Reason: Automerged Doublepost
Old Apr 13, 2008 | 11:58 PM
did you guys mean the spacer is the **** or a piece of ****? lol sorry maybe its cause im drunk i cant comprehend
Old Apr 14, 2008 | 12:11 AM
ColeJJones's Avatar
Bannned
it is a pos
Old Apr 14, 2008 | 12:13 AM
ssmokin's Avatar
piece of ****...had to bore it out to get the bolts to line up with the throttle body...however, now that it fits i must say, its keeps that throttle body pretty cool...
Old Apr 14, 2008 | 12:15 AM
stryder's Avatar
it does the job after you make it fit. and we don't know whats up with the controller, by the instructions it is hooked up correctly so blah. we will know more tomarrow.
Old Apr 14, 2008 | 12:23 AM
ssmokin's Avatar
yeah, i forgot to ground the controller, then i grounded it... its still weird. my AFR is like 15 at WOT so now i dont know if my sensor is fucked up or what. then i threw a p0107=MAP sensor low circuit voltage ...i dunno..i got tired, gonna start messing with it again tomorrow...
i bought the black AC controls on e bay for $25. A far as the red dash pieces, i painted them with gm color match paint and used about 5 coats of clear!
BTW. i wanted to say thanks to Stryder and Colejjones for all your help!
Old Apr 14, 2008 | 12:24 AM
deuce's Avatar
what is that thing supposed to do?
Old Apr 14, 2008 | 12:28 AM
ColeJJones's Avatar
Bannned
^ lol
np, we got your back.
Last edited by ColeJJones; Apr 14, 2008 at 12:28 AM. Reason: Automerged Doublepost
Old Apr 14, 2008 | 12:37 AM
stryder's Avatar
no worries man it will get figured out
Old Apr 14, 2008 | 01:00 AM
devilsown's Avatar
Warrentys are a good thing for you.. go over the wiring very good and make sure its all got good connections. It can short out if ran without a ground. Does not always happen but its not good for it. After checking evertying and its still acting funny let me know and we will get you the rma paperwork. I will need your email adress for these. Best to send me email direct so i can just respond to it. No harm no foul we will fix you up.
Old Apr 14, 2008 | 01:09 AM
ssmokin's Avatar
thanks man...i know, it was a long HOT day with record highs today here in san diego.. simply forgot to tighten down the ground wire bolt. like i said i think it may be with the Map sensor since i threw that code. and with my afr being outta wack i may have a bad sensor..
Old Apr 15, 2008 | 12:02 AM
ColeJJones's Avatar
Bannned
bump for a pimp install
Old Apr 15, 2008 | 12:15 AM
ssmokin's Avatar
thanks hommie.
Old Apr 17, 2008 | 01:08 AM
AjSS's Avatar
Install looks really good, I wouldnt/didnt bother with the tb plate, but it looks good.
