HackAbuse's CRX Project
Old Mar 5, 2007 | 08:56 PM
  #101
06blackg85ss's Avatar
yeah both those things should def be checked
btw Seafoam is the **** man... my poor neighbors thought my lincoln was on fire when I did it..
I kept hearing voices around me but saw no-one.. ended up my one neighbor was about 12 inches away from me.... lol
Old Mar 5, 2007 | 08:58 PM
  #102
Matty's Avatar
Originally Posted by HackAbuse
MY idle is fine right now.
I threw another CEL today:
Code 43 - Fuel Supply System Defective or Malfunctioning
One person is telling me to replace my fuel pump.
Another person is telling me to check all of my electrical connections in relation to the injectors.
It's fuel delivery (my take on it) I would start at the pump if it were me.
Old Mar 5, 2007 | 09:27 PM
  #103
06CorvaltSS's Avatar
MAF gets my vote.
Old Mar 5, 2007 | 10:07 PM
  #104
impulseballer's Avatar
i through a similar or the same CEL. It was the gas cap. Just make sure it's on there tight.
Old Mar 5, 2007 | 11:18 PM
  #105
en0onmai's Avatar
Originally Posted by 06CorvaltSS
MAF gets my vote.
Umm.. HONDAS DONT USE MAFs!!111!1!!!!one!! Damn dude. All their sensors are built into the TB and do NOT use a MAF like the ECOtecs do.
Old Mar 5, 2007 | 11:23 PM
  #106
HackAbuse's Avatar
So I guess I will probably be busting out my multimeter and testing all of my electronics based on the information in my haynes service manual.
I really need a garage 9 degrees is not cutting it for me
Old Mar 5, 2007 | 11:29 PM
  #107
Red07SSNA's Avatar
Hack, Go on line and get a CD factory service manual off e-bay. I got one for my daughter's '94 for under $15 shipped. It will provide you with a heck of a lot more info than the Haynes! Doo it.....dooo it nowwww
Old Mar 5, 2007 | 11:34 PM
  #108
HackAbuse's Avatar
problem is i'll need two
One for my CRX and One for a B18A1 Integra
Old Mar 5, 2007 | 11:37 PM
  #109
Red07SSNA's Avatar
OK.....$30 bucks for real and useful knowledge
Old Mar 5, 2007 | 11:42 PM
  #110
HackAbuse's Avatar
lol, well for now the haynes manuals will do, as soon as i figure out what's causing my problems I will correct them. Then once I have a good stable running engine, I will pull the head and swap my pistons
Old Mar 7, 2007 | 07:07 PM
  #111
show off's Avatar
hey hackabuse, why not leave the option open for when tuning is available and build up the motor as well as turbo on the balt????????? when tunning is ready, ill prolly do some cams and a blower with a smaller pulley! since the gm kit fits our car!
Old Mar 7, 2007 | 07:20 PM
  #112
Delta2.2's Avatar
well now that he has the honda, the cobalts already been stripped and its a lease anyway. so its gonna be returned sooner or later. then buy or lease another car depending on what he likes
Old Mar 7, 2007 | 07:39 PM
  #113
show off's Avatar
ah.. what all mods did he have done to the balt? he had the same model i did
Old Mar 7, 2007 | 07:41 PM
  #114
nctarheel1089's Avatar
look at his part out sale in his sig. click on it
Old Mar 7, 2007 | 08:01 PM
  #115
07LaserBlueSS's Avatar
Hey Jeff, a friend of mine did a motor swap on his honda accord, his motor wouldn't go past 4k, turns out he had the wrong wiring harness in for the motor he put in. I don't know how you would go about checking it...but thats my guess!
P.S. check out this honda...it was a buddy of mines and he did awesome at auto x in it!
http://www.team-crm.com/vid060406.shtml click on Adam Koback's runs! Its a 91 Hatch with a D16 but it was crazy fast!
Old Mar 7, 2007 | 08:05 PM
  #116
NJHK's Avatar
I know why it's not going pass 4 grand...
Tell your boyfriend to get off your lap LOL
Old Mar 7, 2007 | 08:08 PM
  #117
Halfcent's Avatar
I'm old school
I have a question. You seem to be spending a lot of time diagnosing the engine. Don't you plan on rebuilding it anyway? Or at least pulling it? Save your effort since you'll have to take it all apart anyway.
Old Mar 7, 2007 | 08:20 PM
  #118
HackAbuse's Avatar
I was just going to be swapping the pistons, but I'd really like to pinpoint the problem frist.
Old Mar 7, 2007 | 08:21 PM
  #119
NJHK's Avatar
Well...then you're taking out the engine anyways right?
Also, how come just the pistons?
Old Mar 7, 2007 | 08:26 PM
  #120
HackAbuse's Avatar
The head has already been milled and bored/resleeved .020" over, with an all new valvetrain and bottom end, just 2 thousand miles ago.
I don't plan on removing the engine to replace the pistons anyway. Just drop the oil pan, bust off the head, and swap those bitches!
Old Mar 7, 2007 | 08:27 PM
  #121
Halfcent's Avatar
I'm old school
Yeah, pistons pretty much means engine. Whatever the problem is will either become apparent during the process or correct itself in the course of the build.
But, I think its your valve stem oil seals leaking oil past your valve guides.
Old Mar 7, 2007 | 08:28 PM
  #122
HackAbuse's Avatar
Wouldn't that cause me to lose compression though?
Old Mar 7, 2007 | 08:40 PM
  #123
Halfcent's Avatar
I'm old school
No. Compression is maintained by the valve face seating well on the valve seat. The oil in the cylinder head is prevented from leaking down the valve guide by the valve seal. Escessive oil on the stem, exhaust specifically, will burn off when the valve opens. Compression has nothing to do with it.
Old Mar 7, 2007 | 08:44 PM
  #124
HackAbuse's Avatar
I think i might need to have my timing adjusted, any idea how much a shop would charge me to get that done?
Old Mar 7, 2007 | 08:50 PM
  #125
NJHK's Avatar
Which timing? Cam? Ignition?
