How to cheat on any test
I have never seen it done like that, but I have personallypeeled the label off a bottle of water then taped my answers to the bottle facing in the re attached the label. that way all you have to do is look into the bottle
lol i use to do that too, only i would have a small bag of chips on my desk and i would have my notes on the insides of the bag, taped so you cant really see it unless your at my angle, just another little tip, but i never tried that, also what you can do is drink the pop bottle till its just below the label the remove the label and make a piece of paper the same dimensions as ur label the put ur notes on the paper and and tape the notes to the label facing the opposite way of it then attach the label again with tape and you can see through the bottle to read your notes then
WOW!
Now flame me all you want.
But in the amount of time you edit and do this. You should be able to remember what ever you fit on that bottle. Plus you can only make it so small cause im pretty sure if you were reading a bottle closely for the whole test andy normal teacher would notice.
Just my thoughts, guess I never needed to cheat on a test though
