Shortblock Completed!
Old Jan 22, 2010 | 08:33 PM
80vetteL82's Avatar
Here it is....this motor is turning out to be more badass than I had planned. The Mahle pistons I got with the Eagle rotating assembly are unbelievable quality!
Next up, the block is going to be painted Chevy Red with POR15. Then the next step in the assembly...I have the complete heads and intake already, and I just ordered the lifters, pushrods, rocker arms, oil pan/pump/pickup etc....so the next update will hopefully be a complete long block!
Meanwhile, the work on the car continues. The frame is painted on the passenger side, and I need to finish the rest of it. The engine compartment is painted, and I just need to paint the A arms. Then Im going to redo some of the wiring harnesses and vacuum lines, and it should be ready for the new motor.
Old Jan 22, 2010 | 08:49 PM
TurboTechRacing's Avatar
Looks awesome! nice...
Old Jan 22, 2010 | 11:07 PM
80vetteL82's Avatar
Thanks man. It should look good once its painted and has the nice aluminum heads on there.
Old Jan 22, 2010 | 11:09 PM
blue05ss/sc's Avatar
thats gonna be a tight fit in the tc...lol i kid i kid
Old Jan 22, 2010 | 11:10 PM
80vetteL82's Avatar
nah....Ill just jam it in
Old Jan 22, 2010 | 11:11 PM
lol use extra spit
Old Jan 23, 2010 | 12:27 AM
mattcossel29's Avatar
Mahle pistons are awesome quality.. Us LT1 guys swear by them! I am concerned about the eagle crankshaft though.. Is it cast or forged? If it is cast they have been known to break with as little as 400whp or so with slicks under the car...
Old Jan 23, 2010 | 09:33 AM
80vetteL82's Avatar
It is a nodular cast crank, the pistons and rods are forged. I got the whole rotating assembly as a kit from eagle, and they guarantee it to 500hp.
Old Jan 23, 2010 | 12:46 PM
383_Stroker's Avatar
Thats a good start! What displacement is it?
What kind of top end are you putting on it?
Old Jan 23, 2010 | 05:00 PM
80vetteL82's Avatar
I believe the displacement should be 6.2, but dont quote me on that yet. CR will be 11.0:1
Edelbrock Power package-
•Edelbrock 64cc Aluminum E-tec heads, 170cc int, 70cc exh, assembled with Edelbrock hardware
•Edelbrock Hydraulic roller cam- Lift .539 int./.548 exh., Duration 296 int./300 exh.
•Edelbrock Performer RPM Air Gap intake
•Crane Cam Gold race extruded 1.5 roller rocker arms
•Edelbrock Rollin' Thunder Hydraulic lifters
•Edelbrock Hardened Pushrods
•Edelbrock Performer 750cfm
•Edelbrock 110gph fuel pump
I dont know if you are familiar with the Etec heads or not. They are fairly new. Edelbrock took the design of the popular GM Vortec heads, copied all the good designs from it and improved areas that werent ideal from the factory. Plus they made them aluminum rather than cast.
Heres my complete build thread with pictures of the car and parts...
http://www.digitalcorvettes.com/foru...d.php?t=131910
Old Jan 25, 2010 | 11:14 AM
Sounds like it will be a pretty stout set-up! Are you going to get it dynoed or take it down the 1/4 mile when you finish it up?
I've got a decent 383 build up in my truck.. but.. it's a truck..LOL
•Dart 64cc Iron Eagle heads, 2.05 int /1.6 ext valves
•Comp 280 Magnum Hydraulic roller cam- Lift .525 int./.525 exh., Duration 280
•Weiand Team G Single Plane Intake (one tall son of a gun..lol)
•Comp 1.5 roller rocker arms
•Comp Roller lifters
•Comp .100 over Pushrods
•Holley 750cfm
Bottom end
• Eagle Crank (forged)
• Eagle SIR Rods
• Wiseco Forged Pistons
Old Jan 25, 2010 | 11:24 AM
Cobaltsky05's Avatar
no offense to the owner of the thread but IMO id rather have the truck so that when my cobalt or corvette breaks down I have something to tow it with (easily lol)
Old Jan 25, 2010 | 11:45 AM
phillips01's Avatar
better have the deck machined/ looks like their is pitting on the deck //////
Old Jan 25, 2010 | 12:00 PM
hungryhip-ccp's Avatar
AHHHH the good ole days!!!
I had that exact same motor but 10:1 and let me tell you it was beastly for a little 383 on pump!
one of my favorite motor builds! check it out.
https://www.cobaltss.net/forums/show...=1974+firebird
Old Jan 25, 2010 | 12:04 PM
reign1's Avatar
yo chris. new car meet for feb. canyon cruise in malibu.
sorry /threadjack
untuned with 11.5 AFR and only like 24-26* it made 360whp and 399wtrq. with a shitty distributer cutting out at 5500+
I tuned it to 12.8 AFR and 32* timing after i broke it in but never went back to the dyno, but i garentee i picked up 40hp and 50trq
edelbrock claims 460/460 with that package on a ZZ4 which is only 9:1 comp. you should be looking at close to 500/500 crank!!!
Old Jan 25, 2010 | 03:05 PM
80vetteL82's Avatar
•Holley 750cfm
Bottom end
• Eagle SIR Rods
Thanks man, sounds like you have a sweet setup there too. Yah, I will most likely dyno the motor, then also dyno the car. I will most definitely be taking this to the track on the weekends.
I just ordered some more parts today including:
Edelbrock Rollin' Thunder hydraulic lifters
Crane Cams Gold Race Extruded 1.5 full roller rockers
Edelbrock Magnum heat treated pushrods
Moroso 7qt oil pan/pump/and pick up
Thats why Im not overbuilding my balt, just keeping it a fairly aggressive DD. The Corvette has always been my project, and I did have a truck as a DD (a 2003 Avalanche Z71), but gas got to be too much so I sold it and got the SS/TC.
That looks like one sweet build!
Yah, I noticed that. Im sure he plans on doing it, but Ill mention it to him anyways.
Last edited by 80vetteL82; Jan 25, 2010 at 03:05 PM. Reason: Automerged Doublepost
Old Jan 25, 2010 | 03:56 PM
Illini_06SS's Avatar
You can borrow my "Persuader" but you have to promise to give it back!
Old Jan 25, 2010 | 04:00 PM
80vetteL82's Avatar
Old Jan 25, 2010 | 04:13 PM
You laugh, but that was the only way I could get my supercharger to fit under the hood of my 2.4 was to bash the radiator support out of the way to make some room for it...
Old Jan 25, 2010 | 04:49 PM
80vetteL82's Avatar
haha very nice
Old Jan 25, 2010 | 07:45 PM
If you deck the block, keep in mind your compression will rise even more. Mine is cranky sometimes if you get less than ideal 93 octane.
Old Jan 25, 2010 | 08:33 PM
80vetteL82's Avatar
True. Im just going to ask him and see what he thinks. Im sure if it was necessary he will do it. This guy is incredible. He is in his early 70s, and has been doing machine work since he was 8 in his grandfather's shop. Then he went to MIT and worked at Polaroid as an engineer...he's seriously a genius lol.
Old Jan 26, 2010 | 12:44 PM
Since it's already assembled, i'm going to say they don't plan to deck it. It doesn't matter if the surface is pitted so long as it's not on a critical area of the gasket sealing surface.
Old Jan 26, 2010 | 01:06 PM
80vetteL82's Avatar
Sounds good. I cant wait to get this back in the car and on the road. However, once its done I still need to build a 700r4 and figure out what to do with my aluminum differential to keep it from blowing up lol.
