08 lnf cobalt Engine Power Reduced
Old Aug 28, 2014 | 10:29 AM
Powell Race Parts's Avatar
Did you do an engine health test first? Compression test minimum. Then go from there misfires are spark/fuel/air issues clogged cat can cause lotsa issues as well and you have an unknown tune. Not an easy situation good luck with it
Old Aug 28, 2014 | 10:57 AM
Terminator2's Avatar
Originally Posted by Jay P.
Trouble codes are
P0130
P0301
Po300
Po304
P2626
Po030
Po016
P0130 is a wideband O2 performance code in closed loop (control fueling)
P0301 is a misfire on cyl 1
P0300 is a random misfire
P2626 does not come up in my hp tuners list of DTCs
P0030 is a heater circuit code for your wideband O2
P0016 is a crank sensor code.
Replace the crank position sensor first then clear all the codes and fire the car up. if still getting misfire codes and wideband O2 codes replace the wideband O2 (on the O2 housing of the turbo). Clear codes. If still getting misfire codes swap in a frest set of AC Delco plugs gapped to 0.032" If still getting misfire codes compression test time.
Old Aug 28, 2014 | 11:05 AM
Jay P.'s Avatar
Is bosch the recommend brand?
Old Aug 28, 2014 | 11:09 AM
Jay P.'s Avatar
Not getting any missfires any more
Old Aug 28, 2014 | 11:23 AM
Yes I belive the OEM wideband is a bosch.
Old Aug 28, 2014 | 12:30 PM
Jay P.'s Avatar
hopefully this fixes my problem going to go buy it today
Old Sep 1, 2014 | 08:43 PM
Jay P.'s Avatar
I haven't replaced the o2 yet,but I got a scan tool on today and both sensors are not fluctuating I am thinking its a pcm problem since when I reset the engine light it pops back up not 5 seconds after the reset
Old Sep 1, 2014 | 09:13 PM
Jay P.'s Avatar
Anyone no of a good shop/tune shop south texas?
vjoel2011
Oct 2, 2015 12:11 PM
twilson380
Sep 14, 2015 10:52 AM
bucks121
Sep 12, 2015 07:39 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
