08 lnf keeps stalling, hp tuned/bolted.
Car started running rough the other day and stalled out, tried replacing the maf sensor (when the maf was unplugged it would run) and disconnecting the battery, still happening, mods are aem intake, mpx catted dp/exhaust, zzp charge pipes, mpx ic, gms1, and hp tuned. No apparent vacuum leaks. Any input helps, thanks. Currently have no cel besides the maf codes from having it unplugged.
Looking around for leaks doesn't always get the job done unfortunately. Best way to find a leak is to smoke test the system or perform a boost leak test from turbo outlet to the coupler at the throttle body.
Do you have any way to check what you ltft's and stft's are sitting at? Either through your rpd (if you have one) or through some sort of scanner?
All maf codes. It's most definitely going to likely be a boost leak, something happened to one of the pins in the maf connector in the harness, or bad wire in the harness.
