08 lnf keeps stalling, hp tuned/bolted.
Oh right, I missed that you're running an aem intake. I was referring to it being relocated to the lower charge pipe. No biggie. Check to make sure no wires rubbed through somehow. Also ohm out each wire individually to itself at each end of the connector to make sure a wire isn't open, shorting or the resistance isn't too high indicating a bad wire in the extension.
On a brand new ic? I just ohmed out the maf extension its fine, smoke tested the intake/ vac lines for the charge pipes, no leaks. Possibly something wrong with the tune even if it was running fine for about 5 days.
Did you smoke test the entire charge system from the turbo outlet coupling up to the tb as a whole unit? For stuff like this I prefer pressure testing better than smoke testing personally.
Took the bumper off last night to check the ic and charge pipes going to the ic. Found the lower charge pipe blown off at the ic. Dont know how i missed that -____- thanks for all the help guys!
Glad you found it. I have a 6th sense for these things I see them happen all the time. I can spot the signs of a boost leak without even seeing a log.
.... there is no spoon....
patooyee
Oct 1, 2015 01:07 PM
