100k mile tune up
100k mile tune up
by the end of this year I will have to do my 100k tune up. My question is what should I do. I am the only owner, have common sense with cars and working on them , i haven't done anything but oil changes, my car runs almost flawless other then i need a front end alignment. So what do you thik i should do for my 100k tune up? Thanks guys for all suggestions
Spray 100 wet shot of n02. If it holds, keep changing your oil and enjoy your car.
If not, Sorry for your loss.
I was joking please dont do that, Only an idiot like me would do that.
I would say change your air filter, plugs, maybe tranny fluid. I guess it depends on how far you want to go
I would change the Tranny oil , put a fresh set of plugs in her and change the supercharger oil . I would also look at doing all the filters depending on when they were done last ..... If the fuel filter has more than 20K on it ...I would change it.
Change ALL the fluids (oil, SC oil if equipped, trans fluid, brake fluid, coolant)
Change spark plugs
change filters(air, fuel if equipped, trans if auto and you dont get a flush)
serp belt
Change spark plugs
serp belt
Covers all US and Canadian models of Chevrolet Cobalt and Pontiac G5
Every 250 Miles (weekly)
CHeck engine oil level
Check engine coolant level
Check brake and clutch fluid level
Check windshield washer fluid level
Check power steering fluid level (Must be a pontiac G5 thing, dont know why its here)
Check tires and tire pressure
Every 3, 000 Miles (3 months)
All above plus
Change engine oil and oil filter
Every 6, 000 Miles (6 months)
All above plus
Inspect Windshield wiper blades
Check and service battery
Check cooling system
Rotate tires
Check seat belts
Inspect brake system
Every 15, 000 Miles (1 year)
All above plus
Replace interior ventilation filter
Check all underhood hoses
Inspect the suspension, steering components and driveaxle boots
Check the exhaust system
Check the fuel system
Check the engine drivebelts
Every 30, 000 Miles (2 years)
All above plus
Check air filter
Service cooling system (Drain, Flush, Refill)
Change Brake fluid
Every 100, 000 Miles
All above plus
Replace automatic transaxle fluid
Replace manual transaxle lubricant
Replace fuel filter
Replace spark plugs
