12v Power Outlets not working
Old Apr 4, 2007 | 03:38 PM
Claudia SS's Avatar
Okay, the 12v power outlet under the climate control isnt working at all. wtf? And I cant find a fuse for them. Not in the engine bay nor the passenger side kick panel.
Can anybody tell me if there is another fuse box or somthing I am missing?
I need to find the fuse for it so I can power my autometer guages.
Old Apr 4, 2007 | 03:40 PM
Cobalt30's Avatar
the cig. lighter are u using as the 12v?
Old Apr 4, 2007 | 03:51 PM
BlackLS's Avatar
I forget wheather it is inside or under the hood but the fuse will be labeled cigarette lighter most likely. If not look for the one that says APO (accesory power outlet) either way I think it is a 10 or 20 amp fuse.
Old Apr 4, 2007 | 03:59 PM
Cobalt30's Avatar
if its the cig. its under the hood. in the fuse box. far left side. about half way down. yellow fuse it is. i think its a 10a to be exact. i replaced mine yesterday
Old Apr 4, 2007 | 09:29 PM
M88ArRamadi's Avatar
^^^^^^^^^Exactly
Old Apr 4, 2007 | 10:14 PM
MikeyMo84's Avatar
i got the same prob here...just gonna bitch at my service dept to fix it lol...i also gotta have em check out the volume up button on the steering wheel....its erratic and makes the volume go up AND down lol
Old Apr 4, 2007 | 10:18 PM
biohazard's Avatar
Get low
u sure u dont have the vol that goes up automaticly with ur speed. some balts/g5 have that...
climate control is HVAC in the kick panel, i belive theres a cig lighter fuse inside too
Old Apr 5, 2007 | 08:42 PM
MikeyMo84's Avatar
no its not that....im actually trying to turn up the radio and im watching the volume bar on the display go up and down back and forth erratically...i have the speed volume off i hate it
Old Nov 18, 2007 | 05:29 PM
RobHole's Avatar
I found mine, under the hood, labeled as LTR, blue 15A fuse above a 5AMP fuse. 2 below onstar.
Old Nov 18, 2007 | 05:32 PM
ItalianJoe1's Avatar
I've had wheel switches replaces too. They go bad all the time.
Old Sep 8, 2016 | 09:21 PM
Mike Lowe's Avatar
Im having problems with my outlet as well. I have a 2007 Cobalt SS. I check the fuse under the hood and it works good. Even did a test with a multi meter. Both of the outlet don't work. One of them under by the parking brake and the other by the climate control.
Do both outlets use the same fuse? I only see one fuse for "OUTLET" for the fuse box under the hood.
Is there a way for me to test with my multi metter if the fuse is even getting any power? or even reaching the outlet with out short circuiting it?
Old Sep 9, 2016 | 09:29 AM
zeeky420's Avatar
The outlet it self probably went bad I had to change mine it went bad because of tire inflated I had plugged in
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
jmelton327
Sep 26, 2015 10:04 PM
