2.0L LSJ 07 SS S/C Hesitation under boost
Old Dec 30, 2013 | 10:22 PM
chris88z24's Avatar
If I ease into the throttle slowly the car is fine, but if you step on the gas hard it hesitates for a second and then takes off. Any ideas?
-New cat 100 miles ago
-Maintained to spec
If you've had this happen let me know and also what you did to fix it.
Old Dec 30, 2013 | 11:06 PM
thejoey12's Avatar
How many miles on the car and any cels?
Old Dec 31, 2013 | 12:09 AM
chris88z24's Avatar
92k, no check engine lights. No fluid leaks. air filter is a few months old. Fuel filter is probably a year old. Primary oxygen sensor is a few months old too. Cleaned the maf when I did the air filter. Rear o2 is disconnected but that's disabled in HPT.
Old Dec 31, 2013 | 12:23 AM
chris88z24's Avatar
I had the fuel pump recall done. Definitely isn't a weak fuel pump.
MAP sensor?
Old Dec 31, 2013 | 04:27 AM
thejoey12's Avatar
Naaw usually if It's a sensor it will throw a code. I was going to say maf. But you said no codes so I'm not sure
Old Dec 31, 2013 | 12:57 PM
chris88z24's Avatar
Yeah I'm stumped as well. I thought it was the cat but when I took it off it wasn't clogged at all. Replaced it anyway.
Old Dec 31, 2013 | 02:31 PM
Have access to someone with hpt?
Old Dec 31, 2013 | 02:53 PM
CobaltSS 16's Avatar
what spark plugs do you have? look into that.
I would also say MAF and or cat, but looks like you already did them.
Old Dec 31, 2013 | 03:02 PM
kzak104's Avatar
i dont know lsjs, but dirty throttle body?
Old Dec 31, 2013 | 03:33 PM
chris88z24's Avatar
Nah the tb is clean. It also seems to have a rough idle once it's warmed up too.
I used to have hpt but not anymore. Idk anyone close who has it either.
what spark plugs do you have? look into that. I would also say MAF and or cat, but looks like you already did them.
Bkr7eix
Last edited by chris88z24; Dec 31, 2013 at 03:33 PM. Reason: Automerged Doublepost
Old Jan 1, 2014 | 02:34 PM
05g5's Avatar
If you got no cels, everything els is new/clean and in good shape, look into your timing chain? Buy a kit maybe. Might be streched enough to make the motor feel lazy
Just trying to think a little outside the box here. Its not the obvious things. Btw i dont know lsj, but can ypu service your fuel filter? That was HUGE when i did mine
Old Jan 1, 2014 | 04:00 PM
chris88z24's Avatar
The fuel filter is pretty new. I think it's a boost leak I can hear it when I step on the gas.
Old Jan 10, 2014 | 06:54 PM
i944scania's Avatar
Chain is fine..check vac lines to bypass valve
Old Jan 10, 2014 | 07:06 PM
SunburstSS's Avatar
Spark Plugs Good ? Are They Gapped To Specs ?
Old Jan 10, 2014 | 10:47 PM
jp1600's Avatar
Check the butterfly valve on the sc, sometimes they stick. Not the bypass valve, but the valve on the actual sc
Old Jan 11, 2014 | 03:31 PM
chris88z24's Avatar
My vacuum lines were reversed on the replacement blower. Switched them and all is well. Mileage is up too lol
Old Jan 21, 2014 | 12:05 AM
megaman311's Avatar
check for rust inside the coils under the spark boot wire. there could be rust on the screw for which you will get this symptom. if that checks out ok, throttle body will be the issue.
Old Jan 21, 2014 | 11:49 AM
chris88z24's Avatar
Cool never thought to check something like that. You mean where the coil connects to the spark plug tip?
Thanks a lot.
Old Oct 27, 2014 | 12:58 AM
boostbalt's Avatar
I have rust on mine, and this exact problem. Could you please elaborate on the fix? I assume it's new coil packs?
Thank you!
Old Oct 27, 2014 | 01:03 AM
megaman311's Avatar
Use a Phillips screw driver.
Remove screw
Polish rusted screw with 1000 grit sand paper
Reinstall screw
Coat screw head with dielectric grease
Reinstall
Old Oct 27, 2014 | 01:17 AM
boostbalt's Avatar
Remove screw
Reinstall screw
Reinstall
Ahh, so I assume I push the screwdriver up into the "pencil" or boot? And there's a screw head up at the top of the spring?
Thanks!
PS: I'm looking to try new plugs, would yours work well on a 2.8? What gap did you use and what gap do you recommend? Thanks
Old Oct 27, 2014 | 01:33 AM
megaman311's Avatar
not on top of the spring, but where the spring mates with the coil
Old Nov 2, 2014 | 02:15 AM
boostbalt's Avatar
FIXED!
I was having two problems:
  1. Car felt like it hit a brick wall, no power at all, usually at 4K RPM, then it would buck it's way up to 6K. Brutal.
  2. Noticeable hesitation on boost and off boost when high in the RPM range.
The fix to this was:
  • Replaced the fuel pump
  • Replaced the fuel filter
  • Used 1000 grit sandpaper to scrub the spring/coil inside the boot of each coil pack
  • Carefully applied dielectric grease to the inside boot of each coil pack (the grease is an insulator)
  • Installed BRK7EIX-11 spark plugs (NGK) gapped at 0.040 (while the plugs are cold!)
  • Ran Seafoam through the vacuum lines twice
Problems solved, no hesitation to 7k redline, ran the car for 1.5 hours, just like new!
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
