2.2 Hard start and rough idle no power
Old Dec 26, 2006 | 12:52 PM
orangredline's Avatar
Ok so here it is, I drive my girl down town which is like 10 mins away, everyday so she can get a ride to work with her foreman, and today we go out, get in the car I turn the key, the stupid car turns over like 6 times goes through the cycle and shuts off, no start i pull out the key and try again and starts, with very rough idle and stumbles a bit. CEL light is on and flashing i rev it up slowly, CEL is still on but not flashing, back to idle and flashing again. I take it for a spin around the parking lot and the thing will barealy move with like no power. and the thing is it was working fine everyother day.
does anyone else ever heard of this, it is strange to me I though it maybe my oil cap in wich it maybe losing oil pressure, but no i'm thinking an O2 sensor. and the dealer is closed till tomorrow, and i'll have to get it towed down there.
Old Dec 26, 2006 | 01:02 PM
HackAbuse's Avatar
Check your spark plugs
Old Dec 26, 2006 | 01:05 PM
06blackg85ss's Avatar
Flashing CEL usually indicates a misfire, bad coil, plug, or wire.
Old Dec 26, 2006 | 01:13 PM
OK so if i change my plugs, will my light go out or does gm have to reset the CEL cause my car starts so it may not be the coil you can drive it but cannot accel fast, and what would i gap the plugs at. it also has like 45000kms on it.
Old Dec 26, 2006 | 01:23 PM
HackAbuse's Avatar
The CEL will go away on its own
befoer you do anything, check your plugs to make sure they are the problem
Old Dec 26, 2006 | 01:30 PM
cawpin's Avatar
It will go off by itself after 3 drive cycles if everything is ok. Just go to an Autozone and have them scan it for codes, look it up, and do the appropriate fixes. Then have them clear the codes, drive around for a bit and see if the light comes back on.
Oh ****, you're in Canada, replace Autozone with whatever the hell it is up there.
Old Dec 26, 2006 | 01:42 PM
Yea ok that is not an option we have nothing like that is the great white north of FT mcmurray Alberta so maybe disconnect the battery for awhile then it may reset i hope stupid dealer is not open
Old Dec 26, 2006 | 03:20 PM
rally's Avatar
Take it to the dealer, your unmodded i'm guessing so that would be covered by your warranty. A free and easy fix for you.
Old Dec 26, 2006 | 08:19 PM
Halfcent's Avatar
I'm old school
Are you under warranty? Then WHO CARES why it's broke. Bring it in.
A flashing CEL is trying to tell you that bad things are happening. The condition is being seen repeatedly by the CEL and just getting worse. You should stop driving the car. Again, are you under warranty? Good. Park it and have the dealer tow it for free.
If you happen to fix the problem yourself (Are you under warranty? Then why are you fixing it yourself?), the CEL might go away, but the error code will remain stored, and you will want to get it cleared from memory.
Old Dec 27, 2006 | 01:50 AM
Ya I decided that was the best Idea so i called my RS assist and they towed it to GM for free, I just hate my dealer cause they are a bunch of monkeys, but it's a free fix so i'll take it. thanks guys for your input.
Old Dec 27, 2006 | 01:55 AM
roccityroller's Avatar
had the same problem 3 months ago. Ignition control module went causing cylinders 2 & 4 (or 1 & 3) to misfire, there's a TSB out for it, search the forums and you'll find the full TSB Text.
Call the dealer and then you'll have to call roadside assistance, have them tow it to the dealer and then drive a rental car for 2 days. HAVE FUN!
Old Dec 27, 2006 | 08:16 PM
I got the Car towed to the dealer yesterday and I called them today at 10am to tell them what it was doing, so I waited awhile and phoned again at 3:30pm and they told me the car was fixed and they were waiting on the paper work to get done, and it was the Ing module. But I have the car now and it works again, Man they were fast at fixing the car.
Barkleyj605
Oct 24, 2015 12:07 AM
satisfied
Oct 19, 2015 12:35 AM
n20saturn
Sep 21, 2015 01:50 AM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
