2.8 problems
Old Aug 18, 2006 | 07:29 PM
TheYellowSS's Avatar
2.8 problems
Having some issues with the 2.8. Ok this is hard to explain so ill just walk thro it like im racing some one. First gear i shift at about 6400, a very safe range from the rev limit of 7,000 grand. when i shift, i lose most of second gears rpms, so for example i shift at 6400 and it goes down maby a grand then go right back to redline. it takes a second to go down too, i shift at 64 grand when i shift it sits there for a sec then goes down alittle then right back up, same for 3rd two. I have the belt tentioner set to the second hole which is where its suppose to be for a 2.8 pully. could that be the belt still slipping. Or what else could it be. It does shift into second but i lose most of the rpms so its not the clutch.
Old Aug 18, 2006 | 07:35 PM
Tomtwtwtw's Avatar
Actually, that sounds exactly like clutch slipping. If it were the belt, you'd be losing boost, but your car would engage just fine. Sounds like it's not engaging at all from your words, but maybe I'm not reading it right.
Old Aug 18, 2006 | 07:39 PM
to much power for the clutch maby. but i see people all over this sight with the same mods and not having a problem. what would fix the clutch, stage 2 or 3 clutch maby
Old Aug 18, 2006 | 07:42 PM
OniMirage's Avatar
clutch slipping
Old Aug 18, 2006 | 07:43 PM
OniMirage's Avatar
take it easy on the shift and dont power shift anymore cus your done with that clutch time to get something stronger. dunno what to get cus I don't have that issue
Old Aug 18, 2006 | 07:44 PM
so basiclt shift slower, no powershifting( i didnt powershift anyway)
where would be the best place to get a clutch that could handle the power?
Old Aug 18, 2006 | 07:53 PM
Tomtwtwtw's Avatar
I have no personal experience there, but from what I read it seems the Spec Stage 2+ is a good buy.
Old Aug 18, 2006 | 07:59 PM
ggarcia86's Avatar
i want clutchmaster fx300 untill act comes out with something
Old Aug 18, 2006 | 08:12 PM
06blackg85ss's Avatar
damn still no clutch slip here... try shifting higher and dont bang it into 2nd... should be fine. gotta kinda granny shift 1st to 2nd
turbochargedss2012
Sep 20, 2023 12:17 PM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
