2.9 pulley low boost
hi, i have a 2.9 pulley with overzised tensioner pulley and i only see 12 psi, with the 3.1 pulley i see 12 psi too, i live at 6600 feets, so i dont know what happend, the car is not nocking
thanks for all
thanks for all
The boost wont drop from the tune, unless you had some sort of boost reduction. Which stage 2 tune? GM, ZZP, OTTP?
Your elevation will affect your boost level as u suggested. What temp are you performing these boost level tests at? Temperature will affect output as well.
Extreme Dimensions
May 13, 2016 02:01 PM
Timnman
Mar 13, 2016 03:00 PM
jdbaugh1
Mar 11, 2016 05:23 PM
