2 problems/ OverBoosting, and Reverse lights problem
Old Mar 19, 2008 | 03:43 AM
Video2402's Avatar
So, I was driving home tonight and I will remind you right now, I have the stock pulley on my car. I was on teh freeway, floored it in 3rd gear, Was going about 80 mph, I looked and I seen 20 psi. It went from about 14psi to 18 and climbed up to 20, but once it was up there around 17-19, My car kind of stuttered/hiccupped. Any ideas on what it could be? I know it is not right!
Reverse lights dont work, bulbs are fine, fuse is good, checked the wiring, i'm getting no power to my back up lights.
Anybody have any of these problems?
Old Mar 19, 2008 | 03:57 AM
stg2ss's Avatar
hmmm im not sure, but i think i know you? do you have an 05 or 06 red ss/sc?
Old Mar 19, 2008 | 04:32 AM
HackAbuse's Avatar
That problem screams clogged cat
Old Mar 19, 2008 | 04:39 AM
saunders1986's Avatar
your kitty is clogged.... its not meowing right.....
Old Mar 19, 2008 | 11:39 AM
Video2402's Avatar
06 victory red
haha, Thanks guys. I'll take a look.
Old Mar 19, 2008 | 11:45 AM
CobaltVenomSS's Avatar
does ur exhaust sound like this?? cause i had a clogged cat when i dyno'd my car so i pretty much wasted money on the dyno
http://i7.photobucket.com/albums/y29...=slicks012.flv
listen to it when i get in the high rpm's
Old Mar 19, 2008 | 11:46 AM
Raven SS's Avatar
what are ur mods
Old Mar 19, 2008 | 12:31 PM
Video2402's Avatar
Airbox mod, and a muffler.
Raven SS's Avatar
ok u cant blame that cat..
Old Mar 19, 2008 | 12:44 PM
Video2402's Avatar
So you don't think it's the cat?
Old Mar 19, 2008 | 01:02 PM
stg2ss's Avatar
this is a dumb question but how do you get a clogged cat and how do you fix it?
Old Mar 19, 2008 | 01:13 PM
Video2402's Avatar
Dealership or muffler shop.
Old Mar 19, 2008 | 07:58 PM
dealership wont touch it unless there is a code....i know mine is clogged but i dont have the damn code it pisses me off
Old Mar 19, 2008 | 08:07 PM
ditto...... thats why i'm knocking the guts outta mine, and goin back with my code .............. poor kitty will really meow than
Old Mar 19, 2008 | 08:09 PM
Super_SS's Avatar
its not ur cat,its either ur gauge is bad,or u have misfire at high rpms,or might be both
Old Mar 19, 2008 | 08:10 PM
Greased's Avatar
happens when you run super rich AFR's leaves excess gas in your exhaust, not good for cat...
fix it with a new cat or you can blow out your cat turbo style like that one guy with the CTS-V if you guys saw that vid...
hahahaha the popcorn exhaust
Old Mar 19, 2008 | 08:13 PM
SSRedSC's Avatar
If you truly have a clogged cat that car should but running hot and leaking exhaust fumes from everywhere.. You should be able to smell it from inside the cabin. It should run alright for just a little bit then start breaking down under a load.
SKCobalt's Avatar
For your reverse lights, it may be the reverse switch attached either to the shifter linkage (or shifter housing) or on the transmission. That what it seems like to me. I am unsure where this switch is located on these cars. Does anyone else know?
Old Mar 19, 2008 | 08:20 PM
rnjmur's Avatar
There are two things that typically cause this:
1. Clogged Cat - This is pretty typical of the SS/SC
2. Valve not opening - you may have broke a rocker arm
It could be possible that the airflow is being restricted by something else, but unlikely. I would doubt that the gauge is off by that much. I would definately have it looked out especially if you are still under warranty or you can cause engine damage.
Old Mar 20, 2008 | 01:10 AM
Video2402's Avatar
I don't have any check engine lights on or anything
well, one time I was at a light and started accelerating, and my car just died, and smelled like sulfur way bad. Only happened once.
Old Mar 21, 2008 | 03:06 AM
Video2402's Avatar
Well, it ended up being a faulty cat.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
