2005 sedan
Old Jun 3, 2006 | 05:32 PM
zzzzzzzz's Avatar
2005 sedan
noise somewhere in steering or dash over bumbs had shaft put in but same problem also trans doesnt seen right auto trans help please
Old Jun 3, 2006 | 05:33 PM
vB00STw's Avatar
wow...uhm...erm..uhhhh...no comment
Old Jun 3, 2006 | 06:27 PM
Cirrus's Avatar
I believe he is trying to say that there is a noise coming from somewhere in the steering column or dash when he rides of bumps. He had a shaft put in but the problem persisted. Also, the transmission doesn't seem right (?). The car is an automatic.
Old Jun 3, 2006 | 06:32 PM
zzzzzzzz's Avatar
thank you very much lol
Old Jun 3, 2006 | 06:35 PM
zzzzzzzz's Avatar
never drove a 4 speed auto before so not sure how to determine if theres a problem
Old Jun 3, 2006 | 06:59 PM
eazyasone23's Avatar
the hardest shift i get is usually from 1st to 2nd and the rest are smooth.
Old Jun 3, 2006 | 07:03 PM
zzzzzzzz's Avatar
mine seems to not go into over drive
Old Jun 4, 2006 | 01:39 AM
zzzzzzzz's Avatar
do you guys keep the cover on engine on
Old Jun 4, 2006 | 06:18 PM
Cirrus's Avatar
I kept mine on, it doesn't really make a difference though. Most use I can say is sound deadening and a few seconds of fire resistance (but lets hope you never need that)...
Old Jun 4, 2006 | 06:26 PM
zzzzzzzz's Avatar
ok great as you can tell im not to mechanically inclined lol thanks
Old Jun 4, 2006 | 06:27 PM
zzzzzzzz's Avatar
how do i go about putting my pic of car in there like you cirrus
Old Jun 4, 2006 | 06:38 PM
Cirrus's Avatar
You'll need to upload the file somewhere, I personally use http://xs.to/
Then go into 'User CP' up top and click on 'Edit Signature'. Paste the image URL given after you uploaded into the box and you should be good to go. You may need to attach [IMG] and [/IMG] before and after depending which link you select after uploading..
Old Jun 4, 2006 | 06:46 PM
zzzzzzzz's Avatar
Filename: 8de9e2e8fe08[1].jpg testing pic 123 testing
Old Jun 4, 2006 | 06:56 PM
Cirrus's Avatar
Didn't work.
Go to the link I provided above, select your file, and click 'Host Image'
You'll get a whole bunch of different links to choose from. Go to the bottom one which says 'Direct Link' . Copy that, and paste it here.
Then put [IMG] before it and [/IMG] after it.
Old Jun 4, 2006 | 07:03 PM
zzzzzzzz's Avatar
Talking
[img] http://xs101.xs.to/xs101/06231/7dacaf3d89ac[1].jpg[/img] hows this[img] http://xs301.xs.to/xs301/06231/8de9e2e8fe08[1].jpg[/img]
Old Jun 4, 2006 | 07:13 PM
Cirrus's Avatar
I can see it in your signature just fine, you may have chosen the thumbnail link, which may explain why its quite small unless you wanted it to be that way.
zzzzzzzz's Avatar
thinking of removing pin stripping
whats you think
Old Jun 4, 2006 | 07:39 PM
Cirrus's Avatar
whats you think
I had the dealer take mine off, hated it.
Old Jun 4, 2006 | 07:55 PM
zzzzzzzz's Avatar
did you buy car new with pin stripes or used
Old Jun 4, 2006 | 07:57 PM
zzzzzzzz's Avatar
by the way thanks for your help with pics
Old Jun 4, 2006 | 07:58 PM
zzzzzzzz's Avatar
got mine used from dealer with 4100 miles
Old Jun 4, 2006 | 08:11 PM
Cirrus's Avatar
It was new with pinstripes, I think most come that way. Most that I see off the lot have them taken off..
Old Jun 4, 2006 | 08:15 PM
zzzzzzzz's Avatar
ya think i will also what about upgrades i have 15 inch wheel and tires
Old Jun 4, 2006 | 08:50 PM
Cirrus's Avatar
The stock tires, in my opinion, suck. But i'm staying with them til they need replacement.
Check out http://www.tirerack.com/ , you'll find everything you need there
Old Jun 4, 2006 | 08:57 PM
zzzzzzzz's Avatar
stupid ? but how much do you think i can sell my stock tires and rims for
