2006 2.4 Cobalt SC
Old Oct 6, 2016 | 09:24 AM
jdbaugh1's Avatar
Do you have any idea what your AFR is? Looks to me kind of what happens when you're running lean. I had this happen to me one time after I was tuned but then I repositioned the intake and clocked the MAF tube differently and it caused my fueling to be way off and I was running extremely lean and it acted like this.
Old Oct 6, 2016 | 11:12 AM
chevygirl2006's Avatar
Yes why wouldn't the plugs work? I'm on e85 fuel with 80s injectors.
Old Oct 6, 2016 | 02:02 PM
its not the plugs youre having an issue with, its the spark plug gap. Re-gap the spark plugs to around .030" and your problem should be fixed.
Old Oct 6, 2016 | 07:25 PM
infultrator's Avatar
Switched to the plugs you recommended and changed the gap to .034 and the issue is still here. Another video of it.
Old Oct 6, 2016 | 08:40 PM
DFZ24's Avatar
Which spark plugs are you using again????
ACDELCO 41108
ACDELCO 41834
ACDELCO 17
Or the ones that the car brought? Not the kit.
Or one not mentioned above?
Old Oct 6, 2016 | 08:56 PM
ACDELCO 41108
ACDELCO 41834
ACDELCO 17
I've used the stock ones, 41 108s, and xp5263.
Old Oct 6, 2016 | 09:10 PM
You need to log it when that happens. Only way to know what's really going on. Probably that zzp tune lol
Old Oct 6, 2016 | 09:12 PM
You need to log it when that happens. Only way to know what's really going on. Probably that zap tune lol
Thats what I was thinking as well. I'm going to drive to ZZP tomorrow and talk with them about it.
Old Oct 7, 2016 | 12:10 PM
jdbaugh1's Avatar
I don't know why everyone is ignoring this but if you don't have an AFR gauge you need one. If you don't know your AFR quit driving it.
Old Oct 7, 2016 | 06:28 PM
I already asked him that. Didn't get an answer.
Old Oct 7, 2016 | 06:38 PM
  #36
Oh unrelated question, but why do you have a 2.2 speedometer?
  #37
jdbaugh1's Avatar
I know. But he/she just keeps ignoring it but to me I would make sure that is in check way before getting caught up in spark plug gap. Incorrect fueling is a very common problem with a supercharger kit and a canned tune.
Old Oct 7, 2016 | 08:50 PM
  #38
DFZ24's Avatar
Maybe ask for engine bay picture...
Old Oct 9, 2016 | 01:30 PM
  #39
06blackbalt's Avatar
I bet op has a 2.2
Old Oct 9, 2016 | 02:41 PM
  #40
The issue was a bad throttle body. I replaced it and now everything is running well. And yes it is a 2.4.
Old Oct 9, 2016 | 02:45 PM
  #41
Cool glad you got it straight, someone must have swapped your speedo out with a base model one
Old Oct 9, 2016 | 04:12 PM
  #42
Holy mess
Old Oct 9, 2016 | 04:13 PM
  #43
And get a intake that goes into the wheel well. You're sucking in hotter air with that intake.
Old Oct 9, 2016 | 08:20 PM
  #44
DFZ24's Avatar
I'm sucking hot air too, i don't really mind. Is better than sucking water lol
OP, get also a fuse box cover.
Old Oct 9, 2016 | 11:03 PM
  #45
jdbaugh1's Avatar
Surprised it didn't go into engine power reduced mode.
Hexonxonx
Aug 25, 2016 10:24 PM
Ryan3414
Aug 17, 2016 02:36 PM
jdbaugh1
Aug 15, 2016 04:43 PM
Studer
Jul 12, 2016 03:51 PM
Studer
Jul 12, 2016 03:16 PM
