2008 hhr ss brake?
Old Aug 5, 2014 | 09:22 PM
ecotecturbo's Avatar
2008 hhr ss brake?
I just installed pads and rotors on the front and now the brakes are squeaking when i drive it. Any ideas whats wrong?
Old Aug 5, 2014 | 09:46 PM
footballplaya3k's Avatar
Did you lube the pads and shims?
Old Aug 5, 2014 | 10:38 PM
no
Old Aug 5, 2014 | 11:10 PM
tomj77's Avatar
that is why
Old Aug 5, 2014 | 11:19 PM
Its only is the drivers side. So are the pads sticking with no lube?
Old Aug 5, 2014 | 11:34 PM
LNFTX's Avatar
Yeah your gonna wanna clean and lube those calipers pins and shims properly or your gonna have a bad time
Old Aug 6, 2014 | 01:44 AM
tomj77's Avatar
mine actually did the same thing after I changed mine and I lubed everything. figured a rock had gotten in on a wet road so I brake boosted to see if I could heat it up and maybe fix it. worked for a bit, anyway the squeaking went away after a few days.
Old Aug 6, 2014 | 01:53 AM
meatsac69's Avatar
hey at least you guys don't have a bad e-brake mines not worked in a year and ive had mechanics look at it and they said there was nothing wrong lmfao
Old Aug 6, 2014 | 03:58 AM
tomj77's Avatar
check ur calipers, I had my ebrake broken inside the caliper. had to replace it. to do it, just pull the lever the ebrake cable pulls in the caliper and see if the wheel spins.
Old Aug 6, 2014 | 01:52 PM
does it matter what side of the rotor you put the pad with the feeler on it?
Old Aug 6, 2014 | 06:01 PM
tomj77's Avatar
feeler?
Old Aug 6, 2014 | 06:05 PM
LNFTX's Avatar
Its not a feeler it helps hold the shim in place it does matter but im not currently near my car
Old Aug 6, 2014 | 09:41 PM
Im talking about the piece that touches your rotor when the pads get low
Old Aug 6, 2014 | 10:01 PM
meatsac69's Avatar
so you'll never guess why my e brake didn't work lol I can't believe mechanics could not figure out why it didn't work
Old Aug 6, 2014 | 10:04 PM
Shanedude's Avatar
A weed grinder you stashed there once while being pulled over got jammed up and you coudln't raise the e-brake handle.
Old Aug 6, 2014 | 10:51 PM
meatsac69's Avatar
no the right cable detached from the piece that allows the handle to pull both e brake cables, still can't believe no one could figure that out
Old Aug 7, 2014 | 07:26 AM
BlackielawlessSS's Avatar
lube those bad boys up.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
