2010 Cobalt SS Coupe turbo LNF strange issues sunroof, steering, clutch
Ok, this is the only new car I have ever owned that has has so many problems. Just last week I had my SECOND electric steering motor installed under warranty. At the same time, I had the entire sunroof track replaced. Two months before that, my key got stuck in the ignition with the car running. So I have a new cylinder lock under warranty.
All this on a car with only 21,000 miles on it!
Since they replaced my sunroof track and motor, the "tilt" feature doesn't work anymore.
Also, while driving, my clutch pedal makes an annoying "squeaking" noise when I depress it. It gets worse once the car has been driven a while and everything is has warmed up.
My steering wheel also makes this hellish squeak when you make left or right turns. I had the dealer look at it, and they said they fixed it.
Well, the squeak is back on the clutch pedal and the steering wheel.
Anyone else have this squeak problem? If so, how did you go about getting it fixed and what exactly is making the noise?
OVCD
OVCD
Getaway_Driver
40
09-10-2015 09:11 AM
