2010 SS/TC Flutter?
Old May 29, 2011 | 11:00 AM
TurboSS999's Avatar
2010 SS/TC Flutter?
My SS/TC cobalt has 15000 miles on it and it has just recently been causing problems for me. My car loses power completely. I have a GM Stage 1 tune on it and im running 20.8 lbs of boost. Now with this problem im only running no more than 5 lbs. When i get on it, my blow off valve makes a loud flutter noise. Ive had it to the local chevy dealership twice now and they have told me there isnt anything wrong with my car. I also have a K&N short ram CAI and they said that that might be throwing off my MAF. So i dont know what is wrong with my car. Can you guys help me figure this out? Or have any of you guys had this happen to you, and what did you figure out what was wrong?
Thanks Guys
Old May 29, 2011 | 11:14 AM
Doomtor's Avatar
Happened to me once in a while. It happens, then the next day it's solved. I think it has something to do with your bypass valve. I wouldn't worry too much about it. My dealership couldn't find the problem as it's always being intermitent, but as I said, only happened to me 5-6 times in over 2 years of having the car.
Thanks Guys
Old May 29, 2011 | 11:16 AM
RyanJM's Avatar
I have the K&N and highly doubt that is what is cause it. Do you still have the factory airbod setup, if yes sway them out and then bring the car in and their lazy techs can't make up any exuses.
Old May 29, 2011 | 11:19 AM
vahdyx's Avatar
I don't know since I opted out of GMS1 after hearing all the problems behind it.
But from my reading on this site, I'd suggest searching about GMS1 sensors failing, bypass valve issues, purge solenoid and possible boost leaks.
I've read some people getting their sensors fixed and the problem went away, I've read people getting forge motorsports bypass valve and the problem left.
Hope this helps.
Old May 29, 2011 | 11:22 AM
JPizzle's Avatar
I had this problem, and the problem was the MAP sensor on the cold side of the intercooler. It was a little "loose." Wiggle it around (the wires) and just make sure all the wires are connected.
Old May 29, 2011 | 11:35 AM
Ch1ck3n's Avatar
+1 very common problem with dealer installed GMS1
Old May 29, 2011 | 06:01 PM
gotboost?17's Avatar
Nothin Stock
no problems wit lack of power on my stage 1, but i do get a raddle snake noise sometimes usually the first couple times i boost each day......in for results
Old May 29, 2011 | 06:12 PM
TheBoss8688's Avatar
I had the same issue. It was the by pass valvue spring was broken and was screwing everything up
Old May 29, 2011 | 06:24 PM
CrystalRedSS's Avatar
Wouldn't the lower MAP sensor also cause the RPD to not register boost? This happened to me for the second time since owning the car. Was on my way Friday night to see Hangover II and it said Data Not Avaliable on my RPD. Went away later on though. Just pisses me off.
Old May 29, 2011 | 06:32 PM
Nothin Stock
not mine, mine does it wit the dejon spring too
Old May 29, 2011 | 06:33 PM
Nothin Stock
that would be ur wideband happened to me if your talking the air/fuel screan
Old May 29, 2011 | 10:04 PM
TurboSS999's Avatar
It started about 2 months ago, and was doing it about once a week up till a couple days ago. Now it does it every time i start up my car. itll on occasion be normal but otherwise it just does the fluttering.
Old Jun 2, 2011 | 12:55 PM
Viper_4's Avatar
Ok so mine is doing the exact same thing. I am going to check map sensors and possibly cut and re crimp the wire connected to the two map sensors. Other than that I am not sure. Ill let you guys know if i find anything out of wack.
Old Jun 5, 2011 | 03:27 AM
One-Bullet-Banta's Avatar
please post whatever you find out in here, i have had this problem for almost a year now since getting the gm stage 1 and have wasted countless weekends attempting to solve this problem
Old Jun 7, 2011 | 09:14 AM
Viper_4's Avatar
Well I didn't get around to messing the the map sensor connections this weekend. Ended up taking a bike trip to AC. I'm going to try to get to it sometime this week. It shouldn't take long at all since its only a few wires. Ill keep you guys posted once I try it.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
