2010 what the fudge man!!!!
Old Aug 16, 2011 | 08:28 PM
damastah's Avatar
i got 2010 cobalt SS... trifecta tuned... and its falling apart!!!
every time i turn the key to start it, something goes wrong..
sometimes i would hear the starter motor, but it wont crank
sometimes the car just shuts down. first time this happened i thought the black cable on the battery came disconected. checked the trunk. everything was fine. closed the trunk. noticed Guages were moving up and down, tried to turn it on. shuts off again!!!!
happens almost every time.... also my clock gets reset, and AVG MPG gets reset. just like battery got disconected.
Old Aug 16, 2011 | 08:39 PM
Mindrot's Avatar
Take it to the dealership since it's under warranty then.
Edit: nvm you're tuned lol
Old Aug 16, 2011 | 08:41 PM
Coblasts's Avatar
Remove the battery pos and neg and retighten the cables on and wiggle the connection as you do it so that you know they are both tightened down.( there was a problem with the neg bolt on older models)
Also check your pcm conmectors are on tight and clipped in.
Theres a 50 amp fuse in the trunk check that its okay as well.
Check ecm ground as well behind the driver head light I think.
Old Aug 17, 2011 | 12:11 AM
damastah's Avatar
everything is fine
Old Aug 17, 2011 | 12:44 AM
Dart_SI's Avatar
that sucks man. i have a 2010 with 20k miles on it and so far its held up as good as my old 06 civic si i used to have.
well... i did blow a map sensor, but thats not the cars fault. gotta order a new one.
Old Aug 17, 2011 | 12:50 AM
samsumthing's Avatar
sounds like someones car was built on a friday.
Old Aug 17, 2011 | 07:17 AM
BooSSted's Avatar
Originally Posted by damastah
everything is fine
LOL, Obvious everything isn't fine, or you wouldn't be having these problems. Something is loose somewhere. If something was broken, the car wouldn't work at all. This is just one of those little things that you just need to figure out.
Either that or take it to the dealership. They won't know it's tuned.
Old Aug 17, 2011 | 07:29 AM
05Slowline's Avatar
check grounds? i know in the irl theres a ground by the abs, and it's on top of black painted bay....lol.
Old Aug 17, 2011 | 07:49 AM
Coblasts's Avatar
Ignoring the obvious,you stated every rime you turn the key.
The ignition switch could be bad and you have a flaky ign1 voltage, with out the proper diagnostic equipment all you can do is swap things out and guess.
Another thing to look at is the bcm connectors make sure they are seated properly.
Just thought of something another guy on here had similar problems and it was the positive post on the fuse box under the hood was loose or there was something wrong with it.
Old Aug 17, 2011 | 07:53 AM
Melvin's Avatar
see if there are any local trifecta dealers to flash your car back and take it to the dealer. There is definitely a faulty connection some where.
Old Aug 17, 2011 | 10:06 AM
damastah's Avatar
but when i put my key in ACC, lights come on. works fine. put it in ON, same story. but once i turn to crank the motor, sometimes i hear TICK TICK then starts to crank, sometimes i hear TICK then everything shuts down, like the ground to battery got disconected, and sometimes nothing happens, engine cranks as normal
might i add this is the second lock cylinder on my car because first one got stuck, had it replaced by dealership under warranty.
Old Aug 17, 2011 | 10:22 AM
asherby85's Avatar
Do you have any aftermarket sound equipment? Might want to check all the wiring if you do.
Old Aug 17, 2011 | 01:21 PM
Coblasts's Avatar
Follow the ground off the battery and check the connection to the car body in the trunk.
Old Aug 17, 2011 | 01:24 PM
TommyP's Avatar
AWD > FWD
your ground connection on your battery might just be coming loose. I'm having that problem as well. all I do it open the trunk, barely move the connection, and it works fine. Does it randomly every few weeks. Never had my car turn off though.
Old Aug 17, 2011 | 01:39 PM
Coblasts's Avatar
Did you wire in a stereo?or is it stock?
Old Aug 17, 2011 | 02:04 PM
07SSYellow's Avatar
Resident Post Whore/Troll
i had something similar to this happen in my LSJ
i had a bad connection from the battery to the starter, on the starter side so it was ******* everything up
Old Aug 17, 2011 | 03:08 PM
damastah's Avatar
have not checked that...
sounds system still stock..
only mods injen CAI, exhaust, dp, and tune. all my mods in sig
Old Aug 17, 2011 | 03:22 PM
Melvin's Avatar
I can't remember if the RPD will come on with the key in the ON position or not but if it does you should check the voltage on one of the screens see if it is under voltage, I think my stayed around 14.7 but I can't remember its been a while since I drove mine
Old Aug 17, 2011 | 07:04 PM
damastah's Avatar
i have been driving around with rpd side screen on voltage... with the engine off?? have not checked, but it should be 12~13. i will check later. but when the car is on, its chilling at 14.1~14.4 idle. and about 14.2~14.5 at around 2k rpm.
so the battery is pretty much charged.. i dont make a lot of short trips. i do sometimes listen to my music after i turn the car off. but no more than 2 minutes...
the battery is fully charged... im going to take it to my friends shop tommorow, and check the battery/diodes
Old Aug 17, 2011 | 07:06 PM
gotboost?17's Avatar
Nothin Stock
just take it to the dealer, thats y i bought a new car for warranty lol
Old Aug 17, 2011 | 09:25 PM
cranemaster's Avatar
The symptoms your having I've had exactly, it was a loose power connection as described by other people in this thread. I tightened everything (including pushing the fuse into the fuse holder as hard as possible) and it went away.
Old Aug 17, 2011 | 09:27 PM
damastah's Avatar
and say what? i got an intermittent problem with starting the car... ? lol... its going to take days for them to diagnose, and fix.... and most likley they wont find anything wrong with the car, other than the fact its pushing 22psi, and their going to revv the **** out of it...
Old Aug 17, 2011 | 09:35 PM
MastaShaKe_88's Avatar
it might be your crankshaft sensor.. mine did the same thing along with a couple other random problems.. I'm trifecta tuned 2
took it to the dealer, replaced under warranty
Old Aug 17, 2011 | 10:07 PM
Nighthawk243's Avatar
Sounds like an electrical. Was the car ever flooded?
Old Aug 18, 2011 | 12:05 AM
damastah's Avatar
no but i drove it into the ocean once.... lmaooo jkkk. it sounds like electrical to me too.. i dont get it,, last 2 days ive recorded every single start with this thing. leave the camera in my car.. lmaooo. car starts fine now
