2nd gear grind!
Old Jun 21, 2007 | 07:41 PM
bl0wnbalt's Avatar
2nd gear grind!
when shifting into second gear, if i hold the shifter i get a slight grinding noise, not a loud grind like i changed gear without the clutch all the way in just a suttle continuos grinding, however if i shift into 2nd and then immediatley take my hand off the shifter the noise stops, being this is my 3rd manul car ive owned ive grown used to holding my shifter when im in lower gears so its a hard habbit to break, i beleive i also didnt notice this happening until i installed my hurst shifter, one mod i wish i would have never done but i butchered the stock one so bad while taking it out i couldnt replace it if i wanted to
Old Jun 21, 2007 | 07:42 PM
campo165's Avatar
sounds like when you rest your hand, you are almost pushing it out of gear? as in when in second, putting forward pressure on it as to go to third? cept no clutch action.
Old Jun 21, 2007 | 07:45 PM
red06s/c's Avatar
mine use to do that when i 1st got it...always when i shifted into 2nd gear. i know it wasnt me cuz other people have drove it and its done it. i just turned up the radio and 15,000 miles later no tranny problems and i dont hear it anymore
Old Jun 21, 2007 | 07:48 PM
bl0wnbalt's Avatar
not forward pressure, more like holding the shifter in gear so putting pressure down on it, seems like when i put it in 2nd i gotta leave it alone, i cant hold it in 2nd
im gonna put it in 2nd gear and pull the shift linkage forward a little bit, maybe when i installed my shifter i gave it too much room to go further into gear than needed
red06s/c's Avatar
oh my bad wrong problems
Old Jun 23, 2007 | 08:43 AM
Paradox's Avatar
Talking Trans Problem
Had my trans repaired three times and replaced once. Shift pin problem. You start to notice that it is getting harder to put into gear and the throw of the shifter is further before it engages. Next you notice grinding and it is more difficult to put into gear. Eventually you will notice that trans will no longer go into gear and you are stranded. If you are lucky, the car will be in second gear when it breaks and you can drive home slowly.
Good Luck.
Old Jun 23, 2007 | 02:44 PM
MikeyMo84's Avatar
Good Luck.
Can u give more details on this problem?? my cars starting to show the same symptoms and id like to proactively take care of it if neccessary...
what happened and what did you do and what did the service department say and what was done???
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
riceburner
Oct 2, 2015 05:47 PM
