3rd gear
Old Oct 19, 2006 | 06:28 AM
beerbaron105's Avatar
3rd gear
when i open the car up merging onto the highway, 2nd gear close to redline and i try to shift into 3rd gear im locked out for a second then i can pop it in, this never used to occur but now its like the synchros are wearing out. ive never grinded any of the gears! and its not like i do this on a daily basis, but its something ive noticed happen over the past week or so.
Old Oct 19, 2006 | 06:32 AM
eirhed's Avatar
Probably due to the engine rocking on the mounts....try an Ingall's torque damper.
Old Oct 19, 2006 | 10:35 AM
codyss's Avatar
You just need to re-adjust the shift rods under the shifter.
One cable moves when you go front to back and another when you go side to side. If one is slightly out of adjustment it will " lock " you out of certain gears.
If the front to back cable is off you won't be able to fully engage the gear, if the side to side cable is off it will hit the " gates " between gears.
The engine moving isn't causing the problem.
Old Oct 19, 2006 | 05:34 PM
how can i get this fixed at the dealer under warranty without telling them it only happens when your pushing 2nd gear to redline and shifting into 3rd.... lol
Old Oct 19, 2006 | 05:40 PM
Clmbngfrk18's Avatar
just tell them when it happens it has a redline for a reason they know your gonna drive it hard time and again its was made to be
Old Oct 20, 2006 | 01:03 PM
Permafried-'s Avatar
Pretty much, you may as well be honest because if they want to take it for a test drive to investigate the problem they're not going to be able to reproduce it without pushing it. I was wondering how I was going to explain my problem to the dealer (when I upshift, rev or push past 4000rpm I hear kind of a squealing noise, hard to explain) since it's easiest to hear around the redline but if they give me a hard time I'll just say it happens most often when merging on the 400 series highways .
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
