5-6 PSI Max on WOT, NO CEL
Old Sep 24, 2016 | 10:40 PM
ZxZueSxS's Avatar
I have read all of the different threads around the forum and none of the cases are like mine. I have no check engine light and the car is limited to 5-6 psi. However, if i plug a couple vacuum lines i get full boost. I have tested my actuator and it works. I did have a CEL before for my Supercharger bypass valve solenoid and i replaced it and the CEL went away and i thought that would fix the problem and it didnt. I do not have a slipping belt cause i still get full boost with plugged vacuum line, which also means i dont have a boost leak. I am at a loss here, any help here would be appreciated. What would cause the computer to go into an "abuse mode" or not allow boost? Ty in advanced
Edit: I have unplugged the battery for like 30 min to clear everything. Problem still there after.
Old Sep 25, 2016 | 02:13 AM
Sl0wbaltSS's Avatar
You might have a pending code.
Old Sep 25, 2016 | 12:32 PM
mrbelvedere's Avatar
the bypass solenoid Is leaking off
Old Sep 25, 2016 | 03:16 PM
ZxZueSxS's Avatar
it actually is leaking off, when its all hooked up properly the nozzle with the foam over it does leak off. How do i stop this!!!???
Old Oct 1, 2016 | 12:28 PM
ZxZueSxS's Avatar
Can anyone help? cannot figure out why the car is acting like this, only thing i can think of is the tune i got from ZZP is ****. idk
Old Oct 1, 2016 | 01:53 PM
unhook the vacuum line coming from the intake manifold going to the bypass solenoid and plug it that's how you fix it
07GatorSS
Sep 20, 2016 09:09 AM
05RLS2
Sep 9, 2016 09:43 AM
Coolcal444
Sep 3, 2016 07:52 AM
sinisterSF
Aug 27, 2016 08:33 AM
