5th Time and the car is still not fixed !
Old Dec 20, 2005 | 06:23 PM
CobaltSS05's Avatar
Well i have been having problems with me 05 ss s/c It has been sucking air in around the dip stick and after them putting 4 different sets of o rings on the dipstick now it sucks so hard u cant pull the dipstick out at all had to take a big ass screw driver and pry it out after it comes out it goes in and out really easy but when i drive the car it gets sucked on there again and u cant get it out, soooo i take it back again and all they do it lube up the dipstick. Granted it was alot better then the other dealer tapping the dip stick to the tube I just called the Aturney Generals to get papers to fill out on the lemon law. Any ideas?
Old Dec 21, 2005 | 12:46 AM
97cavie24ls's Avatar
im not understanding your dip stick problem
does it keep blowing the dipstick out or something ?
Old Dec 21, 2005 | 01:22 AM
Leafy's Avatar
That could be taken in so many ways...
Old Dec 21, 2005 | 01:58 AM
JapEatr's Avatar
South Central *********
clogged PCV valve or disconnected vacuum line
try checking the compression before calling the lemon law
that way if it is a makor issue, you have proof of what the prob is
edit" try checking the oil filter to see if restricted
i had a bmw filter do this to the stick a few weeks back in the shop i recall
Old Dec 21, 2005 | 01:59 AM
MarcS's Avatar
The Stig
lol that's what I was thinking
Old Dec 21, 2005 | 08:11 AM
CobaltSS05's Avatar
no i thought it was blowing it out until i took it to the other dealer and it was just sucking air around the rings on the dipstick so they got the right rings on there and it has so much vaccume in the crankcase u cant even pull the dipstick out after you drive it, but after you get it out and the pressure is released you can pull it out easy.
Old Dec 21, 2005 | 11:55 AM
JapEatr's Avatar
take the cap off first
Old Dec 21, 2005 | 05:57 PM
CobaltSS05's Avatar
I took the oil cap off and did not help. I was out messing around with the car and the only time that it has that much pressure in it is when i drive it under boost it does not do it when the car is sitting still reving the engine.
Turbo Johnny
Feb 21, 2019 09:41 AM
vjoel2011
Oct 2, 2015 12:11 PM
ashalle2
Sep 16, 2015 10:36 PM
63 Nova SS
Sep 12, 2015 11:21 PM
