starting problem
Old Dec 22, 2005 | 10:27 PM
hardtocope's Avatar
starting problem
today i went in my car and the first time i turned the key over my car would not start, so then i turned the key back and then tried again. it started right up on the second time.. should i have anything to worry about?
Old Dec 22, 2005 | 10:46 PM
Kritter's Avatar
You might be experiencing the cold start problem that many people have experienced. There are many posts on the site about it, and given the weather currently in New York, I'd be thinking that, assuming you haven't abused your engine or anything of course.
Old Dec 22, 2005 | 11:04 PM
BlackSS05's Avatar
its a safety switch. if you dont have the clutch depressed all the way the car wont start. or if you try to come off the clutch as you are starting it it wont start. try it out. you can not start the car if the clutch is not depressed almost all the way.
Old Dec 22, 2005 | 11:06 PM
MarcS's Avatar
The Stig
Need more info, would it try to crank? Make sure your battery is not dead.
I had a cold start issue that I beleive is related to fuel quality. I had this problem while in upstate NY.
Old Dec 22, 2005 | 11:12 PM
hardtocope's Avatar
it cranked but no start.. then i did it again and it started
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
