Abnormally high iat2 temps
Old Aug 22, 2015 | 06:19 PM
Haven07's Avatar
hey guys so I just installed a OttP front mount heat exchanger on my car. I also have dual pass and option b and they are installed according to stages how-to. Just did a pull on my car and my temps got up to 145, so do I have air in the system still?
Old Aug 22, 2015 | 06:39 PM
blueLNFftw's Avatar
Bleed it.
Check pump if working.
Old Aug 22, 2015 | 06:46 PM
Haven07's Avatar
What's the best way to bleed it? Take the restricter out of the air bleed line and let it idle a bit?
Old Aug 22, 2015 | 07:05 PM
Haven07's Avatar
Yea Pump is working , I'm thinking its air, I see the bubbles come out when it's idling and and if I lightly rev it while idling the temps drops fast
Old Aug 23, 2015 | 04:25 PM
southal cobalt's Avatar
what size pulley? thats not too bad if youre running a 2.8 or so.
the opt b is supposed to automatically bleed the air if installed correctly though
Old Aug 23, 2015 | 06:03 PM
Haven07's Avatar
2.9 on a tvs and a ported head
But it's definitely air Ima look into buying some sort of vacuum pump to bleed the air out
Old Aug 24, 2015 | 07:31 AM
Staged07SS's Avatar
Administrator
Administrator
What was the ambient air temp when you did the pull?? Also what gear did you run it out to in? Whats your limiter set at?
Old Aug 24, 2015 | 07:56 AM
Haven07's Avatar
80 ish degrees outside a,d I was in 3rd gear.
Old Aug 24, 2015 | 08:14 AM
Staged07SS's Avatar
Administrator
Administrator
Those aren't terrible temps then.
You can help the Opt. B burp the air faster if you lift the coolant tank up while the car idles.
Ones completely bleed, the opt. b will do the rest of the work for you indefinitely.
Old Aug 24, 2015 | 08:15 AM
Haven07's Avatar
I'll try that out at work today!!
Old Aug 24, 2015 | 10:16 AM
yellowsupercharged06's Avatar
what did you pull too ? my iat's dont like the humidity and heat either.
85* and 75% humidity, if i get on it the IAT's shoot through the roof, but they come back down after a few seconds of driving. I hit 195* one time at 140mph .... e85 helps correct that.
Old Aug 24, 2015 | 10:25 AM
Haven07's Avatar
Only to 120 ish and not on e85 yet
Old Aug 24, 2015 | 10:44 AM
Staged07SS's Avatar
Administrator
Administrator
Recovery is most important. If they drop back down fast that's a good sign things are functioning correctly.
Old Aug 24, 2015 | 11:00 AM
blueLNFftw's Avatar
Park the car sideways on a hill with the passenger side higher.
Top off the option B and let the car run.
This always bleed it quickly before me.
Becareful vac bleeding the cooling system; you can suck the seals out of place on the stock radiators and then they leak.
Old Aug 24, 2015 | 11:22 AM
Haven07's Avatar
Recovery is definitely very fast and didn't know that trick about parking the car on a hill, there are some speed bumps at my job I can try those
Old Aug 24, 2015 | 11:28 AM
blueLNFftw's Avatar
That should be fine.
Or jack up the pass side a little bit.
My driveway is on a small hill and it was plenty.
no_ss
Oct 18, 2015 11:58 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
