? about wipers and lights please help
Old Dec 22, 2008 | 09:06 PM
clutchgeargasgo's Avatar
i live in mass and we just got hammered with ice crap. anyways only one of my winsheild sprayers is spraying fully and the pass side is only half spray. any ideas? next problem my drivers headlight went out i poped the light out and when i pulled it out it went on any ideas there
Old Dec 22, 2008 | 09:34 PM
Erod's Avatar
Moderator Alumni
please read my signature link.
moved to problems and service.
both are 99% sure because of the temp. They shold just work again when it warms up prviding you didn't mess up the bulb when you pulled the headlight.
Old Dec 23, 2008 | 01:00 PM
Coblasts's Avatar
For the sprayer the hole is frozen ,try holding a lighter by them to heat them up with out melting the plastic,otherwise take a good look at the holes to see if you hit them with the ice scraper and in that case you will have to open them back up with a fine sewing needle or pin.
The head light bulb check the filiament closely to see if it is actually broken other wise could be a bad connection(corrosion must be removed and a bit of silcone grease applied
to the socket).
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
