Frost on The Inside?
Old Dec 23, 2008 | 11:59 AM
beamer1341's Avatar
Ive got an 08 ls in the morning i wake up to frost on the inside of my windows im assuming that its the weather seals but not sure if anyone else has had this issue and had a simple fix for it. worse comes to worse dealer
Old Dec 23, 2008 | 12:01 PM
SKCobalt's Avatar
I have had this happen on many different cars. If there is any moisture in the air in the car when you shut it off you will find that you will get frost on the insides of the windows. It just happens. I wouldn't say anything is wrong.
Old Dec 23, 2008 | 01:06 PM
Coblasts's Avatar
Snow covered floor mats etc in the car when melted create a high humidity in the car air .
If you drive with the recirc air on in the cold temps this problem will be 10 x worse because the moisture cannot escape.
The simple fix for this is dry everything out floor mat etc.
satisfied
Oct 19, 2015 12:35 AM
grampss
Sep 27, 2015 08:51 PM
Macgyver2484
Sep 23, 2015 11:36 PM
brickloaf
Sep 21, 2015 02:17 PM
Jacque8080
Sep 9, 2015 09:21 PM
