Abs Light??
Old Mar 21, 2007 | 11:26 PM
Imlikedrpepper's Avatar
Abs Light??
OKay, So my ABS light came on about a week ago. I took it to the dealer, and they sid that there was not problem. The code of cleared, and that night it came back on. Well i drove it to my friends house, parked the car for a couple of hours, i came back it was not on and teh ABS worked fine. As i drove back, it came on again. So it now pretty much does this all the time. It will not be on if i have not drivin the car in a few hours and the ABS will work fine, but after driving a bit, the light will come on and it will not work. I am going to take it to the dealer again. Does any one know the problem this might be? and what do you think i can do if the dealer says it is fine?
Bump, Anyone?
Does anyone not know? Alrightly then....
Last edited by Imlikedrpepper; Mar 21, 2007 at 11:26 PM. Reason: Automerged Doublepost
Old Mar 21, 2007 | 11:29 PM
vacobaltss's Avatar
your best bet is to take it up there right when it acts up if possible so they can at least see what code its setting. if you take it up there and just leave it for a while, its likely they wont find anything wrong because you say it has to be driven a while to act up. intermittent problems tend to be a pain to diagnose because they only act up under certain conditions and its hard to check wiring and things like that when your driving.
Old Mar 22, 2007 | 06:51 AM
denniss's Avatar
Mine had a front wheel sensor replaced within 1000 miles. You shouldn't have any problem getting it fixed.
Dennis
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
