Shifter Problem. Dealer can not fix.
Old Feb 21, 2007 | 09:57 AM
qchadf's Avatar
Shifter knob came off and striped out the threads in the shifter shaft.
There is a permanent back order on the shifter shaft. Because the company that was making it has stopped production and decided not to make any more GMC parts.
The dealer has drilled and retaped shaft to place a different screw to hold it for know until GMC figures out how to get the part made.
Old Feb 21, 2007 | 10:02 AM
nramlow2006's Avatar
dude go after market
Old Feb 21, 2007 | 10:04 AM
3fo893013L's Avatar
x2 ^^
I will be installing my Hurst soon. The OEM shifter is cheap and will break again. Trust me, i've gone thru two already. They won't replace it anymore.
Old Feb 21, 2007 | 11:57 AM
2K5SS/SC?'s Avatar
B&m Enough Said!
Old Feb 26, 2007 | 08:24 AM
qchadf's Avatar
If you change the shifter does the reveres lock out still works?
Old Feb 26, 2007 | 08:39 AM
pvirga88's Avatar
My Shifter Knob is Broken on mine I ordered the part back in March of last year and still no word. I check in with the dealer every other week and it still says Back Order.
I have mine glued on and put a bigger screw in the top of it too.
I was thinking about going after market but my dealer told me that if I install the part it will void the warranty.
They will need to install it and it will run me two hours at $75.00 not including they will have to order it through their accessory department. WHich I think is BullSHit.
Old Feb 26, 2007 | 08:46 AM
Matty's Avatar
Time to get into the Hurst.
Old Feb 26, 2007 | 10:45 AM
show off's Avatar
can you rethread the shifter shaft????? have you tried?
Old Feb 26, 2007 | 05:50 PM
Falcon Fixer's Avatar
No it will NOT void your warranty.PERIOD.
They are lying to you.
Old Feb 26, 2007 | 09:10 PM
z22steve's Avatar
get a short shifter
Old Feb 26, 2007 | 09:39 PM
jeremie's Avatar
um..the stock knob is just pressed onto the shaft. the only bolt in the whole thing is the little torx bolt at the top that pretty much serves no purpose. the knob is pressed on though, so it shouldnt come off that easily. i had to pry mine off with 2 screwdrivers when i put my hurst in..
Old Feb 28, 2007 | 04:48 PM
pvirga88's Avatar
I know they are ********... I really don't care anyway.. I am probably going to get a Short throw soon. I can't take that stupid trim piece falling off every week.
I will just put it back to stock when my lease is up in two years.
Old Mar 21, 2007 | 11:13 PM
qchadf's Avatar
Fixed
Part came in and they fixed it like new took 30days.
Old Mar 22, 2007 | 10:10 AM
fr33k's Avatar
I know ya got yours fixed, but I have some info for the others that might not. The part numbers that most dealers is goin to order for the 06-07 SS/SC shifters are on national backorder. But, the old number, the original part number for those shifters, GM has plenty in stock. Most GM dealerships doesn't even think about trying to find out the old number and to check to see if it is still available.
Below is the original number that is still available and the new number that is on national back order. All the Dealership has to know is the old number and they can order it and get it in in a day or 2.
original: 15854364
new: 25815049
biniecki
Oct 25, 2015 02:23 PM
agentirons
Oct 16, 2015 02:11 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
jthwjde
Sep 7, 2015 09:24 AM
