AC issue
Old Mar 10, 2010 | 12:03 AM
Zdeuce4's Avatar
AC issue
i turbocharged my car back in august and immediately after that i noticed that when i turned the ac on my car would lose idle and die out if i didnt repeatedly tap the gas until it leveled itself and vibrated harshly.
i had tranny bushings only. i concluded it was something in the tune and i got vince to adjust it till it went away.
i just got my new exedy clutch installed and tried it out today. the vibes are harsh as hell now. why does the car do this? would getting a top mount make it go away or does it not have to do with the mounts? i can see if vince can help me again or is there something else i need to worry about.
Old Mar 10, 2010 | 04:37 PM
Zdeuce4's Avatar
lone ranger on this?
Old Mar 10, 2010 | 08:54 PM
BLKLS's Avatar
Its most likely from the mounts and getting a top one will probly make it worse.
Old Mar 10, 2010 | 11:02 PM
Zdeuce4's Avatar
they make the car wanna die? lol thats fkn retarded.
Old Mar 11, 2010 | 12:31 PM
BLKLS's Avatar
If the car wants to die then its not the mounts. Are you saying it dosen't idle? If thats it and it was fine before the clutch its a no brainer take it bake to who put the clutch in.
Old Mar 11, 2010 | 06:36 PM
Zdeuce4's Avatar
it never did this before i got mounts... when i got the mounts and then turbocharged it was real bad. i worked with vince on tuning and it worked ... now i got a new clutch installed and it seemed as if it was back to doing it again. im gonna test it out again later but ill get to the bottom of it. my intent in checking on here was to see if other people had the issue.
Old Mar 11, 2010 | 06:41 PM
Texas SS's Avatar
Dont see how it could be mounts
Old Mar 12, 2010 | 02:15 AM
Zdeuce4's Avatar
i just dont get wut turbocharging does.
iirc its something to do with engine load and the mounts and vibes cause it to be exaggerated.. it happened today but i tapped the gas a couple times and it mellowed out.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
