aeroforce interceptor first!!!!!!!!!!!!!!!!!!!!!!!
Soooo, I found my problem...
IF YOU HAVE AN 05'-07' 2.0L AND THINK YOU HAVE REMOVED THE RED JUMPERS, MAKE SURE THE WHOLE JUMPER WAS REMOVED AND NOT JUST THE RED PLASTIC AROUND THE METAL PART OF THE JUMPER
I was going to put the jumpers back on and try that when I realized that the metal insert was missing from one and sure enough when I looked on the back of the gauges it was still stuck on the two pins!! ARGH!
It's probably not real. You can adjust it though. There is a multiplier that you can enter for it. I think its the same for your MPG as well. I tracked my gas milage average, and the MPG average on the intercepter and did some math to figure out what adjustment I needed to make to it. Never checked to see if the HP matched my dyno or not.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
