air bag light on HELP
Old Dec 1, 2011 | 10:35 AM
chevychad05's Avatar
For quite some time my air bag light has been on, and stays on. I dont know why..i checked the fuse box and nothing seems to be wrong. Any other ideas?
Old Dec 1, 2011 | 10:37 AM
TommyP's Avatar
AWD > FWD
Did you take the seats out recently? Check the plug under the driver seat
Also please don't post the same thread in multiple locations
Old Dec 1, 2011 | 12:18 PM
Mendomar06's Avatar
I don't know if you've checked the wiring under your seat as was stated; but at work I see a lot of cars with this issue and it is usually the air bag module (I'm assuming its the airbag light in the instrument cluster). I work at a Nissan dealership and prices run from about $300 to about $800 so I don't really know what GM will want to charge you. Good luck.
Old Dec 1, 2011 | 12:37 PM
Stamina's Avatar
I had a similar issue. I took it to the dealer and they checked the system, recalibrated the passenger seat sensor, and cleared the code. Not that much longer it came back again. It would randomly come on, sometimes after already driving for a while. It also seemed to be tied to movement of the passenger seatbelt.
Upon inspection, the dealer found that it was due to some chaffing/shorting of the wiring going to the seat belt pretensioner, causing an air bag system fault. Due to it all being one unit, the seat belt assembly had to be replaced.
Old Dec 1, 2011 | 01:34 PM
Chevrolet Cust Svc's Avatar
If you do decide to work with a dealership, please send me a private message with more information so that I may assist.
All the best,
Sarah
GM Customer Service
Old Dec 1, 2011 | 02:59 PM
thanks to all of you for the help, i hope it doesnt cost me..i am in no posistion to spend 300-800 bucks! ... ill take a look under my seat
Old Dec 1, 2011 | 03:30 PM
sorry just trying to get a quick response
Old Dec 1, 2011 | 03:36 PM
Mendomar06's Avatar
I hope so too, I would look into what Stamina mentioned and maybe just tape off the places that rubbing, but I wish you good luck.
Old Dec 1, 2011 | 03:51 PM
royce777's Avatar
it might be your clock spring. mine light is currently on and this will be my third clock springs FML
Old Jul 17, 2012 | 10:54 PM
victoryredturbalt's Avatar
Bulletin No.: 09-09-40-003A
Date: July 26, 2010
Subject: SIR/Airbag Light Illuminated, DTC B0081 and Passenger Presence System (PPS) Code 23 Stored (Replace Passenger Seat Belt Retractor and Re-Route Wire Harness)
Models:
2006-2008 Chevrolet Cobalt Coupe
2008-2010 Chevrolet Cobalt SS Coupe
2006 Pontiac Pursuit Coupe (Canada Only)
2007-2010 Pontiac G5 Coupe Supercede:
This bulletin is being revised to update the model years. Please discard Corporate Bulletin Number 09-09-40-003 (Section 09 - Restraints).
Condition
Some customers may comment that the SIR light is illuminated. Upon investigation, the technician may find the following SDM code stored:
DTC B0081 71: Passenger Presence System Invalid Serial Data Received With Passenger Presence System (PPS) Flash Code of DTC 023
Cause
The wire on the Belt Tension Sensor (BTS), that is part of the retractor assembly, may become open or acquire a ground near the sensor. If the BTS is rotated toward the rear of the vehicle, added stress is applied to the wire bundle that may cause an open or a ground path. The two photos below illustrate the possible effects on the wiring. Each photo indicates the area to investigate at the arrow labeled (1).
Read more: Chevrolet Cobalt LS The service air bag message displays - JustAnswer Chevrolet Cobalt LS The service air bag message displays - JustAnswer
Old Jul 18, 2012 | 10:23 AM
Stamina's Avatar
^ That is what happened to me. Needed a whole new seatbelt tensioner... which is basically the entire seatbelt and assembly. lol
Old Jul 18, 2012 | 10:32 AM
BoostedBeaner's Avatar
Would it be the same if the passenger air bag doesn't turn on when a passenger sits in the seat?
Old Jul 18, 2012 | 05:14 PM
Stamina's Avatar
What happened in my case was I would randomly get an airbag light on the dash. If any airbag code sets then the airbag system is disabled for safety reasons... so yes, sorta.
I eventually figured it out that movement of the passenger seatbelt near where the bottom of it connects to the car would cause the error to occur.
If it's only an issue of if the airbag arms/disarms when the passenger sits in the seat, then that's a seat sensor issue, such as a bad sensor or it needing recalibration.
Old Jul 18, 2012 | 05:19 PM
zrated89's Avatar
replaced the pre tensioner on my passenger side seat belt as well as having to trim the plastic on the seatbelt to allow for the wiring harness to have room without hitting it. You need to pull the code first
Old Jul 18, 2012 | 05:41 PM
Aleksey's Avatar
Had that issue in my 05 LS
Old Jul 18, 2012 | 05:44 PM
user 72239's Avatar
Happened to me to. Cost about 540 bucks to replace
Old Jul 18, 2012 | 11:47 PM
yupp, such a common issue, mine tripped when i put some heavy groceries from costco in the rear floor area, thus pulling the wires (tsb posted above) which are too short in length.
Old Jul 19, 2012 | 01:17 AM
Thanks. I need to get it fixed asap
Old Jul 21, 2012 | 05:18 PM
svt's Avatar
svt
Mine went off today while going 5mph in a parking garage. What's the best way to read the airbag codes? Do I need one of the ODB readers, like the ones in Advance Auto?
Old Jul 22, 2012 | 11:31 AM
Speed_Thrills's Avatar
It's definitely the Passenger Presence Sensor.... Dealership wanted $750 to fix it...
My suggestion - Go to a junk yard and find a NON-WRECKED Cobalt (LS, LT, SS) and buy the entire passenger seat. You can have the dealership swap the parts for a lot cheaper than the $750 they want for a new one.
That's if your warranty has expired.
Old Jul 22, 2012 | 03:59 PM
svt's Avatar
svt
Yeah, it only occurs when somebody sits in the seat. After 15 seconds of somebody sitting down, it throws the code and turns the passenger light off. I guess i'll be searching for a new sensor.
Old Jul 23, 2012 | 12:20 PM
svt's Avatar
svt
I just got off the phone with the dealer and he said that my car has the "Major Guard" warranty, which I purchased when I bought the car. I don't specifically remember purchasing that, but if I did, props to me. Anyhow, has anybody heard of this before? Has anybody ever had experience with it covering any work done to their car? Also, are any of the airbag sensors covered under this warranty? They said it would be good until 100k or 2014, since my car is a 2009.
Major guard link is here: http://www.gmprotectionplan.com/majorguard.html
Old Aug 8, 2014 | 10:04 PM
Cobalt_2LT_159's Avatar
Question Airbag light misery
My 2010 cobalt has been in front end collision which caused my wheel airbag to deploy along with both front seat-belts, these past 2 weeks I've replaced the bag, replaced both seat-belts and used a scan tool to clear the codes (19 codes) and the thing is they all come up status: passed/ passed history but for some reason the dashboard SIR light is still on. I've checked for any loose plugs under the seats and all looks fine to me. Then I went digging on the web and thought it was my clock spring which I'm reusing but I've pulled it out and checked the resistance on them (airbag wire plugs) using a multimeter and concluded that they're fine. So now I'm here asking you guys for any advice that you could share about where I could look or replace in order to make the SIR light go away, I was thinking about replacing the ECU module but since I'm clearing the codes with the MD802 scanner it should be cleared and good to go. I've attached the video with the scanner if you wanna look at it, Thanks in advance.
[IMG][/IMG]
Old Aug 9, 2014 | 09:44 PM
RaginChopsuey's Avatar
I am going to refer you to my thread for the same exact thing. there is also another link for some pictures of where the guy pulled up the carpet to the connector located behind the B pillar. I posted a couple of part numbers and such further down.
https://www.cobaltss.net/forums/prob...sensor-311925/
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
