air conditioner never gets cold...
Old Aug 23, 2008 | 03:52 AM
Black07SS's Avatar
my car had the same thing since the day i bought it almost a year ago. took it in last week and turned out there was a hole in a hose and its covered under warrenty. just waiting on the part to get here.
Old Aug 23, 2008 | 11:43 AM
celicacobalt's Avatar
Mine just started doing this same thing recently. Ive owned it since nov. 2005 and I thought the a/c would last longer than this. i am about to call the dealer to see if its gonna be covered under warranty. I need to take it in anyway cuz my cruise control button is messed up and my trunk carpeting is cut too short.
Old Apr 27, 2009 | 05:05 PM
galeblanc's Avatar
Bump ...
I'm having a similar issue today ... My A/C is shooting out boiling hot air. It happened today and it's probably the 1st time I try to use my A/C since my Cold Air Intake Install.
Could I have done something wrong? Or Am if due for a check-up for leaks? Or a fill-up?
My car is an 06 with 38000 km only. Is this normal?
Old Apr 27, 2009 | 09:13 PM
dsp86's Avatar
putting in an intake wouldnt cause that i sont even think any ac lines are near it. you most likely have a leak or ur compressor is dead. its deff not that it just needs to be filld up so dont waste your money unles you get it filled with dye so when it stops working again they can see where the leak is.
Old Apr 28, 2009 | 10:08 AM
galeblanc's Avatar
Thanks for the advice, I'll bring it to the dealer and hopefully it would be covered under warranty!
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
