Anyone ever replace a wheel bearing?
Old Jun 27, 2013 | 12:14 PM
MrSlickSter06SS's Avatar
Has anyone ever replaced a wheel bearing? I feel my front passenger side is bad because it is howling and making noises when I drive and it gets louder faster i go or even if I turn the wheel to the right and has pressure on that bearing it gets loud.. So what's the easiest way to get this done? Please and thank you.
Old Jun 27, 2013 | 12:38 PM
get a new hub(wheel bearing assembly)
i just did a hub swap and i pulled both sides, it was straight forward
jack the car up, support it, pull wheel off, take off the caliper(2bolts) and the bracket(2bolts) take the pads off and the rotor. break loose the 30mm hub nut, it helps to keep the other side on the ground during this
then there are 3 bolts on the hub, u may need a bearing puller. mine both came off with ease but i had the puller just in case and i did need it after i put a bracket on backward and the rotor didnt go back out
make sure the new hub lines up with the abs sensor and the spindle and repeat the steps backwards or something
compress the caliper too
Old Jun 27, 2013 | 05:34 PM
joshcsepegi's Avatar
Yeah its easy. The hardest part is that hub nut. One time in a fwd buick I had u used the weight of the car and power of the engine to break it loose. Hillbilly style in NC
Old Jun 27, 2013 | 05:38 PM
Lmao!
Old Jun 27, 2013 | 05:40 PM
Alright good deal thanks brotha! And I did get an assembly 109 bucks.. Ill go get a bearing pulley as well I forgot about it thanks for the heads up. Thanks for the help much appreciated!
Old Jun 27, 2013 | 09:42 PM
tomj77's Avatar
I did it a few times on my old sunfire, pretty easy, just a few bolts more than taking off ur rotors
Old Jun 27, 2013 | 09:50 PM
Old Jun 27, 2013 | 09:52 PM
oh yea the hub nut, spray it with some pb blaster(if needed) and use a breaker bar and an extension if u have them. very helpful
Old Jun 27, 2013 | 10:29 PM
sLAsh's Avatar
Not so easy up here in the land of salted highways. My axle popped out of the hub easily but it took hours of beating on the hub with a mallet to get it out of the knuckle
Old Jun 28, 2013 | 12:17 PM
Sachemhockey44's Avatar
Not sure if I'm completely right here but since the noise gets louder when turning to the right, shouldn't it be the front driver side bearing that's bad and needs to be replaced and not the passenger side?
Old Jun 28, 2013 | 12:27 PM
toolman's Avatar
Same here. Hours of beating and then hours of scraping the corrosion out of the aluminum spindle. (not really "hours", but that's what it felt like)
bigdeertz
Nov 17, 2016 09:41 AM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
