Backpressure on stock 2.4 / stock limitations of exhaust
Old Oct 16, 2007 | 06:37 PM
pjk91's Avatar
As some of you know, I recently supercharged my 2.4. I'm still getting crazy readings on my wideband only in open loop (and boost) and someone mentioned that I may have too much backpressure in the exhaust system which is giving me those crazy readings. The 3.34" pulley is boosting 9lbs.
I have a stock exhaust system. I am going to try a backpressure test and see where that gets me, but I don't have anything to compare it to. Does anyone know what the stock backpressure reading should be on the 2.4? Maybe one of the GM techs on here can help?
Old Oct 16, 2007 | 06:38 PM
Sunburst_SS's Avatar
back pressure should not be more then like 2psi at about 2k rpm.....
Old Oct 16, 2007 | 06:41 PM
06blackg85ss's Avatar
sorry man no idea, but I can't see it being that restrictive, get the gmpp setup then, sounds good, and flows better than the ss/sc exhaust, or find someone with a stock ss/sc exhaust and swap it
Old Oct 16, 2007 | 06:47 PM
pjk91's Avatar
Under a load or just sitting in neutral revving to 2000rpm and holding it there
Old Oct 16, 2007 | 06:50 PM
hook up the backpressure tester to the pre-cat o2 bung....start the vehicle and leave it in neutral, bring the rpm's up to 2k rpm and monitor the backpressure gauge.....it should not go more then 2psi
Old Oct 16, 2007 | 06:58 PM
pjk91's Avatar
gotcha. If it does go over 2psi then:
a. clogged cat
b. too restrictive exhaust
c. ?
Old Oct 16, 2007 | 07:00 PM
eh cat's suck... only thing they're good for is chinese food lol
Old Oct 16, 2007 | 07:05 PM
olivecj's Avatar
a. clogged cat
c. ?
Just upgrade to a more free flow exhaust and down pipe and eliminate the cat. Also do you have any vids of it yet, I would love to see how a supercharged 2.4 sounds.
Old Oct 16, 2007 | 07:10 PM
well, if you do the back pressure test in the pre-cat o2 bung and you have excessive back pressure, that would lead to a clogged cat......
if you then do the back pressure test in the bung after the cat and still have excessive back pressure, then that would lead to a plugged muffler/exhaust
Old Oct 16, 2007 | 07:29 PM
pjk91's Avatar
http://smg.photobucket.com/albums/v3...t=100_1706.flv
I need a cat for emissions I think. In this vid, you can't hear the supercharger, intake or exhaust. lol.
RaginChopsuey
Oct 27, 2015 01:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
